assets_shared@b513d1ea6f | ||
blender_fund | ||
blender_fund_main | ||
blender_notes | ||
campaign/simulator | ||
docs | ||
donation-box@643532b279 | ||
GeoLite2-Country_20181002 | ||
logentry_admin | ||
playbooks | ||
templates | ||
.coveragerc | ||
.env.example | ||
.gitignore | ||
.gitmodules | ||
deploy.sh | ||
LICENSE.txt | ||
manage.py | ||
pyproject.toml | ||
README.md | ||
requirements_dev.txt | ||
requirements_prod.txt | ||
requirements.txt | ||
setup.cfg |
Table of Contents
Blender Development Fund
Requirements
- Python 3.10
- virtualenv
Development
Setup
Create and activate a virtual environment using your favourite method, e.g.
python3.10 -m venv .venv
source .venv/bin/activate
Install required packages:
pip install -r requirements_dev.txt
Make a copy of example .env
cp .env.example .env
Initialise submodules included into this repo:
git submodule update --init
Create the database tables and load some basic data to work with using the following commands:
./manage.py migrate
./manage.py loaddata systemuser devfund default_site
./manage.py collectmedia --noinput
Update /etc/hosts
to point to fund.local
, e.g.:
127.0.0.1 fund.local
Create superuser:
./manage.py createsuperuser
The last command creates an admin account that can be used to log in at http://fund.local:8010/admin/.
Run development server
./manage.py runserver 8010
Blender ID
Blender DevFund, as all other Blender web services, uses Blender ID.
For development, Blender ID's code contains a fixture with an OAuth app that should work without any changes to default configuration. To load this fixture, go to your development Blender ID and run the following:
./manage.py loaddata blender_development_fund_devserver
Stripe integration
TODO improve this section.
Follow the official guide for setting up Stripe CLI: https://stripe.com/docs/development/quickstart
Webhook testing
Run a local listener that will make webhook requests to your development server:
stripe listen --forward-to fund.local:8010/webhooks/stripe/
Run background tasks that are created by the webhook code:
./manage.py process_tasks
Documentation
See docs for more detailed documentation.
Testing
Run ./manage.py test --parallel
to run all project's tests.
Use the --reuse-db
option to speed up subsequent test runs.
However, this skips the database migrations; add --create-db
on the CLI to
recreate the test database and run all the migrations when necessary.
GeoIP
The GeoIP database was downloaded from GeoLite2-Country
Deploy
See playbooks.
