This repository has been archived on 2023-10-09 . You can view files and clone it, but cannot push or open issues or pull requests.
659be38760784b51cf17c768cdf74cdd5718ba71
This includes big improvement: - The horizon search is decoupled from the BSDF evaluation. This means using multiple BSDF nodes have a much lower impact when enbaling AO. - The horizon search is optimized by splitting the search into 4 corners searching similar directions to help which GPU cache coherence. - The AO options are now uniforms and do not trigger shader recompilation (aka. freeze UI). - Include a quality slider similar to the SSR one. - Add a switch for disabling bounce light approximation. - Fix problem with Bent Normals when occlusion get very dark. - Add a denoise option to that takes the neighbors pixel values via glsl derivatives. This reduces noise but exhibit 2x2 blocky artifacts. The downside : Separating the horizon search uses more memory (~3MB for each samples on HD viewport). We could lower the bit depth to 4bit per horizon but it produce noticeable banding (might be fixed with some dithering).
Archive of Blender with old branches
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
