5a6035a494aa7e53e9af9a5c47a7d26f67a5bb3e
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
After these commands, run deploy.sh to build the static files and deploy
those too (see below).
All revisions to deploy to production should be on the production branches of all the relevant
repositories.
Make sure you have these aliases in the [alias] section of your ~/.gitconfig:
ff = "merge --ff-only"
cd $projectdir
git status
git stash # if you still have local stuff.
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
# Push the production branch.
git push
workon blender-cloud # activate your virtualenv
cd $projectdir/deploy
./2docker.sh
./build-all.sh # or ./build-quick.sh
./2server.sh servername
To deploy another branch than production, do export DEPLOY_BRANCH=otherbranch before starting
the above commands.
Languages
Pug
51%
Python
33.9%
Sass
6.3%
Shell
5.4%
JavaScript
1.6%
Other
1.8%
