0
0
Blender Developer Documentation.
Go to file
2024-06-19 09:40:43 +02:00
.gitea Gitea: Don't display empty "Default" issue template 2024-02-15 12:08:56 +01:00
docs Release Notes: Add Gabor Noise node 2024-06-19 09:40:43 +02:00
theme_overrides Update/replace Wiki links 2024-01-23 17:12:02 +01:00
.editorconfig Add .editorconfig file 2024-01-30 11:35:43 +01:00
.gitattributes Initial commit, adding readme 2023-12-07 16:37:03 +01:00
.gitignore Git: Add .python-version file to gitignore 2024-03-06 15:37:05 +01:00
hooks.py Silence info message about folder links in navigation.md 2023-12-31 01:19:41 +01:00
LICENSE Add CC-BY-SA 4.0 license file 2023-12-07 17:21:41 +01:00
mkdocs.yml mkdocs: Use custom port number to avoid conflicts 2024-05-27 11:11:34 +02:00
README.md Readme: Add link to #developer-documentation chat 2024-01-23 17:46:25 +01:00
requirements.txt Plugins: Enable redirects plugin 2024-02-09 18:12:07 +01:00
New Blender Developer Documentation platform using Material for MkDocs.
The generated documentation is live on developer.blender.org/docs
This is the successor of the developer Wiki, which was archived in January 2024.
Building this Documentation Offline
The following assumes Python 3, pip, Git and Git LFS are installed.
Set up Git LFS for the current user:
git lfs install
Clone the documentation sources:
git clone https://projects.blender.org/blender/blender-developer-docs.git developer-docs
This will clone the sources into a developer-docs directory inside the current one.
Install all dependencies, such as Material for MkDocs:
python -m pip install -r requirements.txt
Build this documentation with live reloading:
mkdocs serve
Alternatively mkdocs build will generate the documentation as HTML into a site/ directory. Simply open site/index.html in a browser.
