.gitea
Gitea: use full URL for referencing pull requests
2023-03-07 13:24:58 +01:00
.github
Docs: change Git URLs to point projects.blender.org instead of git.blender.org
2023-02-07 14:46:01 +01:00
add_camera_rigs
Create Camera Rigs: fix DoF bone for 2D rig
2022-09-21 15:38:16 +02:00
add_curve_extra_objects
D16656: Add Curve: Extra Objects - Add Curve Spiral Objects not conforming to 3D-Cursor Location
2022-12-03 17:36:19 +02:00
add_curve_sapling
Fix T101985: Willow preset in tree gen addon not usable
2022-11-29 09:21:16 +05:30
add_mesh_BoltFactory
Corrected resource leak when adding in EDIT mode
2022-02-14 17:55:45 +13:00
add_mesh_discombobulator
File headers: use SPDX license identifiers
2022-02-11 16:34:06 +11:00
add_mesh_extra_objects
Fix #104458 : Extra Objects Single vert Mirror fails with Translation
2023-03-01 01:10:10 +01:00
add_mesh_geodesic_domes
2022-02-14 14:47:00 +11:00
amaranth
Amaranth: Improve Open Node Source Image feature
2023-02-28 15:50:43 +01:00
animation_animall
Animall: update French translations
2023-04-14 01:55:10 +02:00
ant_landscape
Cleanup: fix typos
2022-10-14 19:52:42 +02:00
archimesh
Fix #104467 : Archimesh boolean doesn't work in 3.5
2023-03-06 14:51:23 +01:00
blender_id
Cleanup: UI messages fixes and tweaks.
2023-04-17 11:41:34 +02:00
btrace
Fix T98902: Btracer Particle Trace is broken
2022-07-05 11:18:38 +02:00
curve_tools
D16212: Curve Tools: Ensure nested paths in exported SVG look as expected. (Authored by Johan Althoff (teetow))
2022-10-23 01:00:28 +03:00
greasepencil_tools
greasepencil_tools: reduce scope of ssl import
2023-02-28 13:08:19 +11:00
io_anim_bvh
Fix #104510 : X3D & BVH import error with Python 3.11
2023-04-06 19:06:56 +10:00
io_anim_nuke_chan
Cleanup: remove <pep8 compliant> comment
2022-06-03 11:50:32 +10:00
io_coat3D
Cleanup: fix typos
io_curve_svg
Official add-ons: fix printf-style format translation for i18n
2022-11-15 11:13:22 +01:00
io_export_dxf
io_import_dxf
Fix #104531 : DXF importer zero division error
2023-04-18 20:12:13 +02:00
io_import_palette
Fix 104401: Import .ase files with swatch groups
2023-02-13 10:45:14 +01:00
io_mesh_atomic
Atomic Blender: Get nodes with their types instead of names
2023-02-09 23:02:28 +01:00
io_mesh_ply
Cleanup: Remove setting polygon loop total
2023-04-12 08:46:40 -04:00
io_mesh_stl
Cleanup: fix typos in blender addons
2022-08-09 19:24:13 +02:00
io_mesh_uv_layout
io_mesh_uv_layout: speed up png export with OIIO (x7)
2023-04-13 20:25:42 +10:00
io_scene_3ds
Export_3ds: Fixed key error in matrix calculation
2023-05-08 00:34:12 +02:00
io_scene_fbx
Revert "FBX Export: Fix export of meshes with polygons in different order to loops"
2023-04-28 19:28:11 +02:00
io_scene_gltf2
io_scene_gltf2: quiet error running when context.space is None
2023-04-30 12:57:20 +10:00
io_scene_obj
io_scene_x3d
io_shape_mdd
magic_uv
Cleanup: fix a few issues in UI messages
2023-02-23 16:42:37 +01:00
materials_library_vx
Cleanup: fix source comment typos
2022-03-15 18:31:13 +01:00
materials_utils
Fix T104270: Error in materials_utils "unregister" function
2023-02-01 23:13:12 +11:00
measureit
Cleanup: fix typos
mesh_inset
Cleanup: fix typos
mesh_snap_utilities_line
Fix T103356: 'NoneType' object has no attribute 'is_valid'
2022-12-20 12:02:43 -03:00
mesh_tiny_cad
mesh_tissue
Cleanup: quiet warnings with descriptions ending with a '.'
2023-02-28 13:18:47 +11:00
mesh_tools
Cleanup: fix typos
node_wrangler
Node Wrangler: Fix #104555 , multiple operators using virtual sockets
2023-04-23 20:18:30 +02:00
object_carver
Assign modifiers to variables instead of getting them by name
2023-02-27 21:51:16 +01:00
object_collection_manager
Collection Manager: Fix "Add/Remove nested from selection". Task: T69577
2022-08-30 08:41:19 -04:00
object_fracture_cell
Cleanup: fix various typos
2022-06-30 17:21:18 +02:00
object_print3d_utils
3D-Print Export: less agressive filename sanitation
2023-03-29 20:06:06 +04:00
object_scatter
Scatter Objects: Add documentation and tracker urls
2023-04-15 23:01:27 -04:00
pose_library
Pose library: fix context menu
2023-03-30 11:15:36 +02:00
power_sequencer
Cleanup: quiet float argument to in type warning
2023-02-28 13:21:57 +11:00
precision_drawing_tools
Cleanup: fix typos
presets
Sun Position: capitalize preset names
2023-04-14 18:56:31 +02:00
render_copy_settings
render_povray
Fix povray rendering metaballs with materials
2023-04-04 19:45:13 +10:00
rigify
Rigify: bump version.
2023-02-07 17:54:26 +02:00
space_view3d_brush_menus
space_view3d_brush_menus: Improve brush icon support.
2022-04-10 01:10:26 -04:00
space_view3d_math_vis
Math Vis: replace deprecated bgl module
2022-07-28 12:29:39 -03:00
space_view3d_pie_menus
Fix #104431 : Pie Menu Editor Switch: Can't switch to File Browser
2023-02-23 14:05:56 -03:00
space_view3d_spacebar_menu
Spacebar Menu: remove old pose library from menu
2022-04-07 11:23:26 +02:00
space_view3d_stored_views
Stored Views: Fix error when Lock 'To 3D Cursor' is active
2022-05-18 12:56:25 +02:00
storypencil
Fix #104912 : Storypencil - If Meta is selected allows TAB
2023-03-12 09:29:58 +01:00
sun_position
Sun Position: Cleanup: remove unused code
2023-04-14 20:43:49 +02:00
system_demo_mode
ui_translate
Minor update to ui_translate addons to cleanup output.
2023-04-17 14:34:56 +02:00
viewport_vr_preview
VR Scene Inspection: I18n: enable translation of UI messages
2023-02-27 08:39:51 +01:00
.gitignore
add cycles folder to gitignore
2018-10-29 12:49:40 +01:00
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
2022-02-11 16:05:07 +11:00
camera_turnaround.py
copy_global_transform.py
Copy Global Transform: add tracker URL
2023-04-11 17:25:20 +02:00
curve_assign_shapekey.py
Curve Assign Shape Keys: replace deprecated bgl module
2022-07-21 11:03:42 -03:00
curve_simplify.py
depsgraph_debug.py
Added a location info line to indicate where buttons are.
2023-03-27 15:34:30 +02:00
development_edit_operator.py
fix accidentally re-added license header
2022-06-13 23:03:01 +02:00
development_icon_get.py
Fix T101708: Bug when joining nodes with thick lines
2022-10-20 13:15:36 +02:00
development_iskeyfree.py
Cleanup: remove "Tweak" event type
2022-03-02 17:33:31 +11:00
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
io_import_images_as_planes.py
Fix T103359: Images as Planes: texture extension not applying
2022-12-23 11:51:26 -03:00
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py
Fix #104441 : Bsurfaces: get modifiers with their type instead of name
2023-02-27 22:58:51 +01:00
mesh_f2.py
mesh_looptools.py
Cleanup: fix typos
node_arrange.py
node_presets.py
Fix T90845: Add missing geometry node type
2022-02-17 17:35:30 +11:00
object_boolean_tools.py
Fix T98953: Typo in property name.
2022-06-17 11:33:32 +02:00
object_color_rules.py
Object Color Rules: fix object selection
2022-06-10 09:57:29 +02:00
object_edit_linked.py
object_skinify.py
Skinify: fix shape generation
2023-03-01 01:36:52 +01:00
paint_palette.py
real_snow.py
Real Snow material update
2022-06-08 15:35:40 +02:00
render_freestyle_svg.py
render_ui_animation_render.py
Fix T101239: UI Animation Render: Attribute error when running in background
2022-09-21 10:18:38 +02:00
space_clip_editor_refine_solution.py
Migrate to an updated motion tracking principal point property
2022-11-22 11:55:37 +01:00
space_view3d_3d_navigation.py
space_view3d_align_tools.py
Align Tools: allow undo for all operators and presets for advanced
2022-10-20 13:15:43 +02:00
space_view3d_copy_attributes.py
Fix #104036 : Copy Attributes does not work on faces
2023-02-09 22:01:34 +01:00
space_view3d_modifier_tools.py
Fix T103455: Modifier tools add-on don't support GPencil modifiers
2022-12-26 12:32:00 +05:30
system_blend_info.py
system_property_chart.py
system_property_chart: support custom properties
2022-07-22 15:59:27 +10:00
