Dalai Felinto
41c4ae35e9
It basically makes sure that the approval queue does not get crawled. Ref: !264 |
.gitea/issue_template | ||
abuse | ||
access | ||
apitokens | ||
assets_shared@c6cc2d73f8 | ||
blender_extensions | ||
common | ||
constants | ||
emails | ||
extensions | ||
files | ||
notifications | ||
playbooks | ||
public/media | ||
ratings | ||
releases | ||
reviewers | ||
stats | ||
teams | ||
users | ||
.env.example | ||
.eslintignore | ||
.eslintrc.js | ||
.gitignore | ||
.gitmodules | ||
.pre-commit-config.yaml | ||
AUTHORS | ||
deploy.sh | ||
LICENSE | ||
logo-source.svg | ||
manage.py | ||
pyproject.toml | ||
README.md | ||
requirements_dev.txt | ||
requirements_prod.txt | ||
requirements.txt | ||
setup.cfg | ||
utils.py |
Table of Contents
Blender Extensions
Free and open source add-ons and themes for Blender.
Requirements
- Python 3.10
- virtualenv
libmagic
:sudo apt-get install libmagic1
in Debian/Ubuntu,brew install libmagic
on OSX.
Development
Setup
Create and activate a virtual environment using your favourite method, e.g.
python3.10 -m venv .venv
source .venv/bin/activate
Install required packages:
pip install -r requirements_dev.txt
Make a copy of example .env
cp .env.example .env
Initialise submodules included into this repo:
git submodule update --init
Create the database tables and load some basic data to work with using the following commands:
./manage.py migrate
./manage.py loaddata **/fixtures/*.json
It's also possible to generate fake add-on data using the following command:
./manage.py generate_fake_data
Update /etc/hosts
to point to extensions.local
, e.g.:
127.0.0.1 extensions.local
Run development server
./manage.py runserver 8111
Now http://extensions.local:8111 should be ready to work with and it should be possible to
log into http://extensions.local:8111/admin/ with admin
/admin
Blender ID
Blender Extensions, as all other Blender web services, uses Blender ID. Blender Extensions can also receive Blender ID account modifications such as badge updates via a webhook.
For development, Blender ID's code contains a fixture with an OAuth app and a webhook that should work without any changes to default configuration. To load this fixture, go to your development Blender ID and run the following:
./manage.py loaddata blender_extensions_devserver
N.B.: the webhook view delegates the actual updating of the user profile to a background task, so in order to see the updates locally, start the processing of tasks using the following:
./manage.py process_tasks
Blender ID and staging/production
For staging/production, create an OAuth2 application in Blender ID using Admin › Blender-ID › OAuth2 applications -> Add:
- Redirect URIs:
https://extensions.staging.blender.org/oauth/authorized
(https://extensions.blender.org
for production); - Client type: "Confidential";
- Authorization grant type: "Authorization code";
- Name: "Blender Extensions Staging" (or "Blender Extensions" for production);
Copy client ID and secret and save them as BID_OAUTH_CLIENT
and BID_OAUTH_SECRET
into a .env
file:
export BID_OAUTH_CLIENT=<CLIENT ID HERE>
export BID_OAUTH_SECRET=<SECRET HERE>
Create a webhook using Admin › Blender-ID API › Webhooks > Add:
- Name: "Blender Extensions Staging" (or "Blender Extensions" for production)";
- URL:
https://extensions.staging.blender.org/webhooks/user-modified/
(orhttps://extensions.blender.org/webhooks/user-modified/
for production); - App: choose the app created in the previous step;
Copy webhook's secret into the .env
file as BID_WEBHOOK_USER_MODIFIED_SECRET
export BID_WEBHOOK_USER_MODIFIED_SECRET=<WEBHOOK SECRET HERE>
Pre-commit hooks
Make sure to enable pre-commit hooks after installing requirements from requirements_dev.txt
pre-commit install
This will enable formatting pre-commit checks for Django templates, Python and JS modules.
Testing
To simply run the test suit use
./manage.py test
To run tests and generate a coverage report use
coverage run manage.py test && coverage html
and then open htmlcov/index.html
with your favourite browser.
Deploy
See playbooks.
License and Copyright
The platform source code is available under the GPLv3 or later. Early versions of the platform are inspired by Mozilla Addons Server. List of authors is available in the AUTHORS file.
