.gitea
Gitea: use full URL for referencing pull requests
2023-03-07 13:26:14 +01:00 |
.github
GitHub mirror: change Git URLs to point projects.blender.org instead of git.blender.org
2023-02-07 14:46:48 +01:00 |
add_mesh_clusters
Update 'bl_info' use 'doc_url' instead of 'wiki_url'
2020-03-05 12:26:13 +11:00 |
automat
Cleanup: quiet warnings registering add-ons
2021-07-30 17:38:13 +10:00 |
exact_edit
Some minor spelling fixes.
2021-05-26 10:45:21 -04:00 |
io_vector
Cleanup: remove <pep8 compliant> comment
2022-06-03 11:52:13 +10:00 |
lighting_hdri_shortcut
mocap
netrender
Fix error registering netrender
2021-07-30 17:18:25 +10:00 |
np_station
object_fracture_crack
.gitignore
Cleanup: redundant gitignore
2017-07-25 16:04:25 +10:00 |
add_dimension.py
animation_motion_trail.py
camera_overscan.py
Update class names after api changes to Blender
2021-09-05 23:24:09 -04:00 |
development_class_viewer.py
development_ui_classes.py
io_export_after_effects.py
After Effects export: fix crash when trying to export some meshes
2023-01-06 16:23:31 +01:00 |
io_import_sound_to_anim.py
io_scene_open_street_map.py
mesh_easy_lattice.py
The apply_as parameter of modifier_apply was removed due to operator split.
2020-07-15 11:40:02 +03:00 |
mesh_selectbuffer.py
mesh_show_vgroup_weights.py
Cleanup: remove <pep8 compliant> comment (no longer needed)
2022-06-07 21:12:54 +10:00 |
object_animrenderbake.py
object_animrenderbake: suppress errors registering
2020-10-16 15:09:31 +11:00 |
object_batch_rename_datablocks.py
object_creaprim.py
Fix error with object_creaprim handler being lost
2021-08-03 09:34:16 +10:00 |
object_mesh_versions.py
render_auto_save.py
render_cube_map.py
render_renderslot.py
render_time.py
render_to_print.py
space_clip_editor_autotracker.py
space_view3d_render_settings.py
UI: Do not use term 'Subsurf'
2020-06-07 18:17:31 -04:00 |
system_keyboard_svg.py
system_project_folder.py
