Add-ons bundled with Blender releases
Go to file
2023-05-31 10:09:22 +08:00
.gitea Gitea: use full URL for referencing pull requests 2023-03-07 13:24:58 +01:00
.github Docs: change Git URLs to point projects.blender.org instead of git.blender.org 2023-02-07 14:46:01 +01:00
add_camera_rigs Create Camera Rigs: fix DoF bone for 2D rig 2022-09-21 15:38:16 +02:00
add_curve_extra_objects D16656: Add Curve: Extra Objects - Add Curve Spiral Objects not conforming to 3D-Cursor Location 2022-12-03 17:36:19 +02:00
add_curve_sapling Fix T101985: Willow preset in tree gen addon not usable 2022-11-29 09:21:16 +05:30
add_mesh_BoltFactory Corrected resource leak when adding in EDIT mode 2022-02-14 17:55:45 +13:00
add_mesh_discombobulator File headers: use SPDX license identifiers 2022-02-11 16:34:06 +11:00
add_mesh_extra_objects Fix #104458: Extra Objects Single vert Mirror fails with Translation 2023-03-01 01:10:10 +01:00
add_mesh_geodesic_domes File headers: use SPDX license identifiers 2022-02-14 14:47:00 +11:00
amaranth Amaranth: Improve Open Node Source Image feature 2023-02-28 15:50:43 +01:00
animation_animall AnimAll: fix translations 2022-08-29 00:20:47 +02:00
ant_landscape Cleanup: fix typos 2022-10-14 19:52:42 +02:00
archimesh Fix #104467: Archimesh boolean doesn't work in 3.5 2023-03-06 14:51:23 +01:00
blender_id Official add-ons: fix printf-style format translation for i18n 2022-11-15 11:13:22 +01:00
btrace Fix T98902: Btracer Particle Trace is broken 2022-07-05 11:18:38 +02:00
curve_tools D16212: Curve Tools: Ensure nested paths in exported SVG look as expected. (Authored by Johan Althoff (teetow)) 2022-10-23 01:00:28 +03:00
greasepencil_tools greasepencil_tools: reduce scope of ssl import 2023-02-28 13:08:19 +11:00
io_anim_bvh Fix #104510: X3D & BVH import error with Python 3.11 2023-04-06 19:06:56 +10:00
io_anim_nuke_chan Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_coat3D Cleanup: fix typos 2022-10-14 19:52:42 +02:00
io_curve_svg Official add-ons: fix printf-style format translation for i18n 2022-11-15 11:13:22 +01:00
io_export_dxf File headers: use SPDX license identifiers 2022-02-14 14:47:00 +11:00
io_import_dxf Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_import_palette Fix 104401: Import .ase files with swatch groups 2023-02-13 10:45:14 +01:00
io_mesh_atomic Atomic Blender: Get nodes with their types instead of names 2023-02-09 23:02:28 +01:00
io_mesh_ply PLY: Fix T103203 export with UVs 2022-12-14 18:16:38 +03:00
io_mesh_stl Cleanup: fix typos in blender addons 2022-08-09 19:24:13 +02:00
io_mesh_uv_layout UV Layout: replace deprecated bgl module 2022-09-21 20:38:06 -03:00
io_scene_3ds Import_3ds: Added world matrix transform 2023-04-08 12:26:50 +02:00
io_scene_fbx FBX IO: Bump minor version after recent improvements to FBX import. 2023-04-03 15:18:42 +02:00
io_scene_gltf2 glTF exporter: Fix #106566 : uri encoded, only for uri, not filename 2023-04-05 17:45:12 +02:00
io_scene_obj Cleanup: fix a few issues in UI messages 2023-02-23 16:42:37 +01:00
io_scene_x3d Fix #104510: X3D & BVH import error with Python 3.11 2023-04-06 19:06:56 +10:00
io_shape_mdd Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
magic_uv Cleanup: fix a few issues in UI messages 2023-02-23 16:42:37 +01:00
materials_library_vx Cleanup: fix source comment typos 2022-03-15 18:31:13 +01:00
materials_utils Fix T104270: Error in materials_utils "unregister" function 2023-02-01 23:13:12 +11:00
measureit Cleanup: fix typos 2022-10-14 19:52:42 +02:00
mesh_inset Cleanup: fix typos 2022-10-14 19:52:42 +02:00
mesh_snap_utilities_line Fix T103356: 'NoneType' object has no attribute 'is_valid' 2022-12-20 12:02:43 -03:00
mesh_tiny_cad Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
mesh_tissue Cleanup: quiet warnings with descriptions ending with a '.' 2023-02-28 13:18:47 +11:00
mesh_tools Cleanup: fix typos 2022-10-14 19:52:42 +02:00
node_wrangler Node Wrangler: Added proper labels for merging shader nodes 2023-03-28 02:33:43 +02:00
object_carver Assign modifiers to variables instead of getting them by name 2023-02-27 21:51:16 +01:00
object_collection_manager Collection Manager: Fix "Add/Remove nested from selection". Task: T69577 2022-08-30 08:41:19 -04:00
object_fracture_cell Cleanup: fix various typos 2022-06-30 17:21:18 +02:00
object_print3d_utils 3D-Print Export: less agressive filename sanitation 2023-03-29 20:06:06 +04:00
object_scatter Scatter Objects: replace deprecated bgl module 2022-07-28 12:29:35 -03:00
pose_library Pose library: fix context menu 2023-03-30 11:15:36 +02:00
power_sequencer Cleanup: quiet float argument to in type warning 2023-02-28 13:21:57 +11:00
precision_drawing_tools Cleanup: fix typos 2022-10-14 19:52:42 +02:00
presets UI: Update deep grey community theme 2022-05-30 09:07:59 +02:00
render_copy_settings Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
render_povray Fix povray rendering metaballs with materials 2023-04-04 19:45:13 +10:00
rigify Rigify: bump version. 2023-02-07 17:54:26 +02:00
simple_deform_helper Refactor: update version 2023-05-31 10:09:22 +08:00
space_view3d_brush_menus space_view3d_brush_menus: Improve brush icon support. 2022-04-10 01:10:26 -04:00
space_view3d_math_vis Math Vis: replace deprecated bgl module 2022-07-28 12:29:39 -03:00
space_view3d_pie_menus Fix #104431: Pie Menu Editor Switch: Can't switch to File Browser 2023-02-28 11:23:45 -03:00
space_view3d_spacebar_menu Spacebar Menu: remove old pose library from menu 2022-04-07 11:23:26 +02:00
space_view3d_stored_views Stored Views: Fix error when Lock 'To 3D Cursor' is active 2022-05-18 12:56:25 +02:00
storypencil Fix #104912: Storypencil - If Meta is selected allows TAB 2023-03-12 09:29:58 +01:00
sun_position Sun Position: respect proper GPL version for geo.py 2023-03-29 21:14:13 +02:00
system_demo_mode Cleanup: fix various typos 2022-06-30 17:21:18 +02:00
ui_translate Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
viewport_vr_preview VR Scene Inspection: I18n: enable translation of UI messages 2023-02-27 08:39:51 +01:00
.gitignore add cycles folder to gitignore 2018-10-29 12:49:40 +01:00
add_curve_ivygen.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
animation_add_corrective_shape_key.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
bone_selection_sets.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
camera_turnaround.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
copy_global_transform.py Copy Global Transform: allow mirroring of pasted transforms 2023-03-10 12:30:21 +01:00
curve_assign_shapekey.py Curve Assign Shape Keys: replace deprecated bgl module 2022-07-21 11:03:42 -03:00
curve_simplify.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
depsgraph_debug.py Added a location info line to indicate where buttons are. 2023-03-27 15:34:30 +02:00
development_edit_operator.py fix accidentally re-added license header 2022-06-13 23:03:01 +02:00
development_icon_get.py Fix T101708: Bug when joining nodes with thick lines 2022-10-20 13:15:36 +02:00
development_iskeyfree.py Cleanup: remove "Tweak" event type 2022-03-02 17:33:31 +11:00
io_anim_camera.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_export_paper_model.py File headers: use SPDX license identifiers 2022-02-11 16:34:06 +11:00
io_export_pc2.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
io_import_BrushSet.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_import_images_as_planes.py Fix T103359: Images as Planes: texture extension not applying 2022-12-23 11:51:26 -03:00
lighting_dynamic_sky.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
lighting_tri_lights.py File headers: use SPDX license identifiers 2022-02-11 16:34:06 +11:00
mesh_auto_mirror.py Assign modifiers to variables instead of getting them by name 2023-02-27 21:51:16 +01:00
mesh_bsurfaces.py Fix #104441: Bsurfaces: get modifiers with their type instead of name 2023-02-27 22:58:51 +01:00
mesh_f2.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
mesh_looptools.py Cleanup: fix typos 2022-10-14 19:52:42 +02:00
node_arrange.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
node_presets.py Fix T90845: Add missing geometry node type 2022-02-17 17:35:30 +11:00
object_boolean_tools.py Fix T98953: Typo in property name. 2022-06-17 11:33:32 +02:00
object_color_rules.py Object Color Rules: fix object selection 2022-06-10 09:57:29 +02:00
object_edit_linked.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
object_skinify.py Skinify: fix shape generation 2023-03-01 01:36:52 +01:00
paint_palette.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
real_snow.py Real Snow material update 2022-06-08 15:35:40 +02:00
render_freestyle_svg.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
render_ui_animation_render.py Fix T101239: UI Animation Render: Attribute error when running in background 2022-09-21 10:18:38 +02:00
space_clip_editor_refine_solution.py Migrate to an updated motion tracking principal point property 2022-11-22 11:55:37 +01:00
space_view3d_3d_navigation.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
space_view3d_align_tools.py Align Tools: allow undo for all operators and presets for advanced 2022-10-20 13:15:43 +02:00
space_view3d_copy_attributes.py Fix #104036: Copy Attributes does not work on faces 2023-02-09 22:01:34 +01:00
space_view3d_modifier_tools.py Fix T103455: Modifier tools add-on don't support GPencil modifiers 2022-12-26 12:32:00 +05:30
system_blend_info.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
system_property_chart.py system_property_chart: support custom properties 2022-07-22 15:59:27 +10:00
