0
0
Add-ons bundled with Blender releases
Go to file
Sebastian Sille b42d686277 Import_3ds: Improved distance cue node setup
Change node position if distance cue was found
2024-05-13 22:55:12 +02:00
.gitea Docs: Replace most wiki links with links to new developer docs 2024-01-18 17:29:15 +01:00
.github Docs: Replace most wiki links with links to new developer docs 2024-01-18 17:29:15 +01:00
add_camera_rigs Fix Add Camera Rigs after 4.0 API changes 2023-09-27 13:19:02 +02:00
add_curve_extra_objects
add_curve_sapling Fix: Avoid race condition creating directory 2024-02-07 15:45:49 +01:00
add_mesh_BoltFactory Mesh: Update addons for auto smooth removal 2023-10-20 16:53:43 +02:00
add_mesh_discombobulator
add_mesh_extra_objects Add Mesh Extra Objects: Bump version 2024-01-16 22:06:37 +01:00
add_mesh_geodesic_domes
amaranth Support loading add-ons without an active key-config 2023-12-20 12:28:10 +11:00
animation_animall Fix #105292: AnimAll: Error in load_post 2024-04-24 09:48:55 +02:00
ant_landscape
archimesh Fix #104981: Archimesh: Remove usage of SHARP distribution on Glossy BSDF 2023-11-07 09:36:23 +01:00
blender_id
btrace
curve_tools
greasepencil_tools GPencil Tools: Optimize Undo for Rotate Canvas 2024-04-14 21:56:22 +02:00
hydra_storm
io_anim_bvh io_anim_bvh: escape strings when constructing data-paths 2024-04-16 13:56:43 +10:00
io_anim_nuke_chan
io_coat3D Fix: Use correct displacement_method property 2023-12-04 19:12:10 +01:00
io_curve_svg
io_export_dxf
io_import_dxf Fix #105316: Error import dxf in scene collection 2024-05-08 12:56:07 +02:00
io_import_palette Fix add-ons with Python 3.12 by replacing "imp" with "importlib" 2024-01-31 08:39:11 +11:00
io_mesh_atomic Shaders: update for Principled BSDF changes 2023-09-25 19:29:00 +02:00
io_mesh_stl STL: mark python addon as legacy (built-in C++ one exists now) 2023-12-23 23:08:30 +02:00
io_mesh_uv_layout Export UV Layout: fix property descriptions 2023-11-21 18:20:33 +01:00
io_scene_3ds Import_3ds: Improved distance cue node setup 2024-05-13 22:55:12 +02:00
io_scene_fbx Fix #105298: Import FBX: TypeError - 'NoneType' is not iterable 2024-04-28 12:50:28 +02:00
io_scene_gltf2 Cleanup: quiet warning for debug builds on startup 2024-05-02 11:26:21 +10:00
io_scene_x3d Import_x3d: Fixed light radius variable 2024-03-18 08:20:19 +01:00
io_shape_mdd
magic_uv
materials_library_vx
materials_utils Fix #105096: Material Utilities: Clean Material Slots fails to remove unused slots 2024-01-11 12:23:47 +01:00
measureit
mesh_inset
mesh_snap_utilities_line PyAPI: use the build option instead of the preference 2024-04-12 21:19:21 +10:00
mesh_tiny_cad
mesh_tissue License Headers: use SPDX-FileCopyrightText for mesh_tissue 2024-03-07 13:18:33 +11:00
mesh_tools
node_wrangler Node wrangler: remove viewer focus operator 2024-04-02 18:20:23 +02:00
object_carver Fix add-ons with Python 3.12 by replacing "imp" with "importlib" 2024-01-31 08:39:11 +11:00
object_collection_manager Collection Manager: Bump versions. #69577 2023-10-31 05:18:01 -04:00
object_fracture_cell
object_print3d_utils 3D-Print: Fix #82760 error whith no objects selected 2024-03-23 14:51:36 +04:00
object_scatter
pose_library
power_sequencer Support loading add-ons without an active key-config 2023-12-20 12:28:10 +11:00
precision_drawing_tools
presets Anim: add theme colors for new 'GENERATED' key type 2024-04-15 10:45:21 +02:00
render_copy_settings
render_povray Fix: Missing keyword for mesh sharpness angle argument 2023-10-24 09:35:39 +02:00
rigify Fix #105241 (Rigify): remove the deprecated keying flag. 2024-03-18 15:53:23 +02:00
space_view3d_brush_menus Support loading add-ons without an active key-config 2023-12-20 12:28:10 +11:00
space_view3d_math_vis Math Vis Console - fixed errors drawing quaternions and eulers 2023-10-14 13:04:24 +02:00
space_view3d_pie_menus 3D Pie menu: Support pivotbottom for selected objects 2024-01-12 12:01:27 +01:00
space_view3d_spacebar_menu Mesh: Update addons for auto smooth removal 2023-10-20 16:53:43 +02:00
space_view3d_stored_views Fix: Avoid race condition creating directory 2024-02-07 15:45:49 +01:00
storypencil Support loading add-ons without an active key-config 2023-12-20 12:28:10 +11:00
sun_position Sun Position: update translation 2024-04-16 20:07:15 +02:00
system_demo_mode
ui_translate I18N: Disable checks on original messages during extraction. 2024-05-06 12:41:48 +02:00
vdm_brush_baker Fix #117150: VDM brush baker warning on startup 2024-01-16 01:44:32 +01:00
viewport_vr_preview
.gitignore
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
camera_turnaround.py
copy_global_transform.py Copy Global Transform: add camera baking & relative copy-paste 2024-04-16 14:26:25 +02:00
curve_assign_shapekey.py
curve_simplify.py
depsgraph_debug.py
development_edit_operator.py
development_icon_get.py
development_iskeyfree.py
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py Cleanup: strip trailing space 2023-11-09 14:05:23 +11:00
io_import_images_as_planes.py Import images: add file handler 2024-04-10 10:13:41 +02:00
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py Fix #105026: BSurfaces: 'ToolSettings' object has no attribute 'use_snap_project' 2023-11-25 10:11:45 -03:00
mesh_f2.py
mesh_looptools.py
node_arrange.py
node_presets.py
object_boolean_tools.py
object_color_rules.py
object_edit_linked.py
object_skinify.py
paint_palette.py
real_snow.py Fix: Use correct displacement_method property 2023-12-04 19:12:10 +01:00
render_freestyle_svg.py Cleanup: strip trailing space 2023-11-09 14:05:23 +11:00
render_ui_animation_render.py
space_clip_editor_refine_solution.py
space_view3d_3d_navigation.py
space_view3d_align_tools.py
space_view3d_copy_attributes.py Copy Attributes: fix Copy Visual Scale 2023-10-17 16:32:29 +02:00
space_view3d_modifier_tools.py
system_blend_info.py
system_property_chart.py
