.gitea
Docs: Replace most wiki links with links to new developer docs
2024-01-18 17:29:15 +01:00 |
.github
add_camera_rigs
Fix Add Camera Rigs after 4.0 API changes
2023-09-27 13:19:02 +02:00 |
add_curve_extra_objects
Extra objects: Fix TypeError when torus knot added
2023-08-01 13:41:10 +02:00 |
add_curve_sapling
Fix: Avoid race condition creating directory
2024-02-07 15:45:49 +01:00 |
add_mesh_BoltFactory
Mesh: Update addons for auto smooth removal
2023-10-20 16:53:43 +02:00 |
add_mesh_discombobulator
Remove bl_options from menus which caused tests to fail
2023-09-07 17:50:38 +10:00 |
add_mesh_extra_objects
Add Mesh Extra Objects: Bump version
2024-01-16 22:06:37 +01:00 |
add_mesh_geodesic_domes
License headers: use SPDX-FileCopyrightText for all addons
2023-06-15 16:54:05 +10:00 |
amaranth
Support loading add-ons without an active key-config
2023-12-20 12:28:10 +11:00 |
animation_animall
Fix #105009: AnimAll: Error when inserting key on string attribute
2023-11-17 14:07:24 +01:00 |
ant_landscape
Merge branch 'blender-v3.6-release'
2023-06-19 21:48:14 -04:00 |
archimesh
Fix #104981: Archimesh: Remove usage of SHARP distribution on Glossy BSDF
2023-11-07 09:36:23 +01:00 |
blender_id
btrace
curve_tools
Curve tools: Calculate length on multiple curves
2023-08-16 23:12:05 +02:00 |
greasepencil_tools
hydra_storm
Hydra Storm: prepare for MaterialX export support
2023-09-07 19:11:48 +02:00 |
io_anim_bvh
Cleanup: autopep8 on io_anim_bvh
2023-08-09 17:56:56 +10:00 |
io_anim_nuke_chan
io_coat3D
Fix: Use correct displacement_method property
2023-12-04 19:12:10 +01:00 |
io_curve_svg
io_export_dxf
io_import_dxf
io_import_palette
Fix add-ons with Python 3.12 by replacing "imp" with "importlib"
2024-01-31 08:39:11 +11:00 |
io_mesh_atomic
Shaders: update for Principled BSDF changes
2023-09-25 19:29:00 +02:00 |
io_mesh_stl
STL: mark python addon as legacy (built-in C++ one exists now)
2023-12-23 23:08:30 +02:00 |
io_mesh_uv_layout
Export UV Layout: fix property descriptions
2023-11-21 18:20:33 +01:00 |
io_scene_3ds
IO: Importing multiple 3DS files at once
2024-03-08 19:21:50 +01:00 |
io_scene_fbx
FBX IO: Export corner normals instead of face normals
2024-02-07 03:36:03 +01:00 |
io_scene_gltf2
Merge branch 'blender-v4.1-release'
2024-03-09 16:03:55 +01:00 |
io_scene_x3d
Fix: Missing keyword for mesh sharpness angle argument
2023-10-24 09:35:39 +02:00 |
io_shape_mdd
magic_uv
Fix #104729. Added missing OperatorStrokeElement keywords.
2023-07-02 12:29:45 +02:00 |
materials_library_vx
materials_utils
Fix #105096: Material Utilities: Clean Material Slots fails to remove unused slots
2024-01-11 12:23:47 +01:00 |
measureit
mesh_inset
mesh_snap_utilities_line
Snap Utilities Line: switch line direction according to mouse position
2024-01-18 01:40:12 -03:00 |
mesh_tiny_cad
mesh_tissue
License Headers: use SPDX-FileCopyrightText for mesh_tissue
2024-03-07 13:18:33 +11:00 |
mesh_tools
node_wrangler
Node Wrangler: make users of GN node groups independant
2024-02-12 11:18:56 +01:00 |
object_carver
object_collection_manager
Collection Manager: Bump versions. #69577
2023-10-31 05:18:01 -04:00 |
object_fracture_cell
Fix: Update Cell Fracture for removal of old style context override
2023-07-19 21:40:03 +02:00 |
object_print3d_utils
3D-Print: use new C++ STL exporter
2023-12-23 23:00:28 +02:00 |
object_scatter
pose_library
Pose Library: Tweak to the add-on description
2023-09-20 11:44:14 +02:00 |
power_sequencer
precision_drawing_tools
presets
UI: Update Theme Presets
2024-01-17 16:27:32 +01:00 |
render_copy_settings
Copy Render Settings: Add support for Cycles, Eevee and Workbench settings.
2023-08-25 18:41:18 +02:00 |
render_povray
rigify
Rigify: bump version.
2024-02-05 19:49:04 +02:00 |
space_view3d_brush_menus
space_view3d_math_vis
Math Vis Console - fixed errors drawing quaternions and eulers
2023-10-14 13:04:24 +02:00 |
space_view3d_pie_menus
3D Pie menu: Support pivotbottom for selected objects
2024-01-12 12:01:27 +01:00 |
space_view3d_spacebar_menu
space_view3d_stored_views
storypencil
sun_position
Sun Position: update translations
2024-02-03 15:15:57 +01:00 |
system_demo_mode
ui_translate
vdm_brush_baker
Fix #117150: VDM brush baker warning on startup
2024-01-16 01:44:32 +01:00 |
viewport_vr_preview
.gitignore
add cycles folder to gitignore
2018-10-29 12:49:40 +01:00 |
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
camera_turnaround.py
copy_global_transform.py
Copy Global Transform: Remove use of INSERTKEY_XYZ_TO_RGB flag
2024-01-15 11:12:07 +01:00 |
curve_assign_shapekey.py
curve_simplify.py
depsgraph_debug.py
development_edit_operator.py
development_icon_get.py
development_iskeyfree.py
Is key Free: Adjust character width for East Asian languages
2023-09-08 13:25:56 +02:00 |
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
Cleanup: strip trailing space
2023-11-09 14:05:23 +11:00 |
io_import_images_as_planes.py
Fix #116962: Image as plane fails with EEVEE next
2024-01-10 11:12:23 +01:00 |
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py
Fix #105026: BSurfaces: 'ToolSettings' object has no attribute 'use_snap_project'
2023-11-25 10:11:45 -03:00 |
mesh_f2.py
mesh_looptools.py
node_arrange.py
node_presets.py
object_boolean_tools.py
object_color_rules.py
object_edit_linked.py
object_skinify.py
paint_palette.py
real_snow.py
render_freestyle_svg.py
render_ui_animation_render.py
space_clip_editor_refine_solution.py
space_view3d_3d_navigation.py
space_view3d_align_tools.py
space_view3d_copy_attributes.py
Copy Attributes: fix Copy Visual Scale
2023-10-17 16:32:29 +02:00 |
space_view3d_modifier_tools.py
system_blend_info.py
system_property_chart.py
