.gitea
Docs: Replace most wiki links with links to new developer docs
2024-01-18 17:29:15 +01:00
.github
add_camera_rigs
Fix Add Camera Rigs after 4.0 API changes
2023-09-27 13:19:02 +02:00
add_curve_extra_objects
Extra objects: Fix TypeError when torus knot added
2023-08-01 13:41:10 +02:00
add_curve_sapling
Fix: Avoid race condition creating directory
2024-02-07 15:45:49 +01:00
add_mesh_BoltFactory
Mesh: Update addons for auto smooth removal
2023-10-20 16:53:43 +02:00
add_mesh_discombobulator
Remove bl_options from menus which caused tests to fail
2023-09-07 17:50:38 +10:00
add_mesh_extra_objects
Add Mesh Extra Objects: Bump version
2024-01-16 22:06:37 +01:00
add_mesh_geodesic_domes
License headers: use SPDX-FileCopyrightText for all addons
2023-06-15 16:54:05 +10:00
amaranth
Support loading add-ons without an active key-config
2023-12-20 12:28:10 +11:00
animation_animall
Fix #105292 : AnimAll: Error in load_post
2024-04-24 09:48:55 +02:00
ant_landscape
Merge branch 'blender-v3.6-release'
2023-06-19 21:48:14 -04:00
archimesh
Fix #104981 : Archimesh: Remove usage of SHARP distribution on Glossy BSDF
2023-11-07 09:36:23 +01:00
blender_id
btrace
curve_tools
Curve tools: Calculate length on multiple curves
2023-08-16 23:12:05 +02:00
greasepencil_tools
GPencil Tools: Optimize Undo for Rotate Canvas
2024-04-14 21:56:22 +02:00
hydra_storm
Hydra Storm: prepare for MaterialX export support
2023-09-07 19:11:48 +02:00
io_anim_bvh
io_anim_bvh: escape strings when constructing data-paths
2024-04-16 13:56:43 +10:00
io_anim_nuke_chan
io_coat3D
Fix: Use correct displacement_method property
2023-12-04 19:12:10 +01:00
io_curve_svg
io_export_dxf
io_import_dxf
Fix #105316 : Error import dxf in scene collection
2024-05-08 12:56:07 +02:00
io_import_palette
Fix add-ons with Python 3.12 by replacing "imp" with "importlib"
2024-01-31 08:39:11 +11:00
io_mesh_atomic
Shaders: update for Principled BSDF changes
2023-09-25 19:29:00 +02:00
io_mesh_stl
STL: mark python addon as legacy (built-in C++ one exists now)
2023-12-23 23:08:30 +02:00
io_mesh_uv_layout
Export UV Layout: fix property descriptions
2023-11-21 18:20:33 +01:00
io_scene_3ds
Import_3ds: Improved distance cue node setup
2024-05-13 22:55:12 +02:00
io_scene_fbx
Fix #105298 : Import FBX: TypeError - 'NoneType' is not iterable
2024-04-28 12:50:28 +02:00
io_scene_gltf2
Cleanup: quiet warning for debug builds on startup
2024-05-02 11:26:21 +10:00
io_scene_x3d
Import_x3d: Fixed light radius variable
2024-03-18 08:20:19 +01:00
io_shape_mdd
magic_uv
Fix #104729 . Added missing OperatorStrokeElement keywords.
2023-07-02 12:29:45 +02:00
materials_library_vx
materials_utils
Fix #105096 : Material Utilities: Clean Material Slots fails to remove unused slots
2024-01-11 12:23:47 +01:00
measureit
mesh_inset
mesh_snap_utilities_line
PyAPI: use the build option instead of the preference
2024-04-12 21:19:21 +10:00
mesh_tiny_cad
mesh_tissue
License Headers: use SPDX-FileCopyrightText for mesh_tissue
2024-03-07 13:18:33 +11:00
mesh_tools
node_wrangler
Node wrangler: remove viewer focus operator
2024-04-02 18:20:23 +02:00
object_carver
object_collection_manager
Collection Manager: Bump versions. #69577
2023-10-31 05:18:01 -04:00
object_fracture_cell
Fix: Update Cell Fracture for removal of old style context override
2023-07-19 21:40:03 +02:00
object_print3d_utils
3D-Print: Fix #82760 error whith no objects selected
2024-03-23 14:51:36 +04:00
object_scatter
pose_library
Pose Library: Tweak to the add-on description
2023-09-20 11:44:14 +02:00
power_sequencer
precision_drawing_tools
presets
Anim: add theme colors for new 'GENERATED' key type
2024-04-15 10:45:21 +02:00
render_copy_settings
Copy Render Settings: Add support for Cycles, Eevee and Workbench settings.
2023-08-25 18:41:18 +02:00
render_povray
Fix: Missing keyword for mesh sharpness angle argument
2023-10-24 09:35:39 +02:00
rigify
Fix #105241 (Rigify): remove the deprecated keying flag.
2024-03-18 15:53:23 +02:00
space_view3d_brush_menus
space_view3d_math_vis
Math Vis Console - fixed errors drawing quaternions and eulers
2023-10-14 13:04:24 +02:00
space_view3d_pie_menus
3D Pie menu: Support pivotbottom for selected objects
2024-01-12 12:01:27 +01:00
space_view3d_spacebar_menu
space_view3d_stored_views
storypencil
sun_position
Sun Position: update translation
2024-04-16 20:07:15 +02:00
system_demo_mode
ui_translate
I18N: Disable checks on original messages during extraction.
2024-05-06 12:41:48 +02:00
vdm_brush_baker
Fix #117150 : VDM brush baker warning on startup
2024-01-16 01:44:32 +01:00
viewport_vr_preview
.gitignore
add cycles folder to gitignore
2018-10-29 12:49:40 +01:00
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
camera_turnaround.py
copy_global_transform.py
Copy Global Transform: add camera baking & relative copy-paste
2024-04-16 14:26:25 +02:00
curve_assign_shapekey.py
curve_simplify.py
depsgraph_debug.py
development_edit_operator.py
development_icon_get.py
development_iskeyfree.py
Is key Free: Adjust character width for East Asian languages
2023-09-08 13:25:56 +02:00
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
Cleanup: strip trailing space
2023-11-09 14:05:23 +11:00
io_import_images_as_planes.py
Import images: add file handler
2024-04-10 10:13:41 +02:00
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py
Fix #105026 : BSurfaces: 'ToolSettings' object has no attribute 'use_snap_project'
2023-11-25 10:11:45 -03:00
mesh_f2.py
mesh_looptools.py
node_arrange.py
node_presets.py
object_boolean_tools.py
object_color_rules.py
object_edit_linked.py
object_skinify.py
paint_palette.py
real_snow.py
render_freestyle_svg.py
render_ui_animation_render.py
space_clip_editor_refine_solution.py
space_view3d_3d_navigation.py
space_view3d_align_tools.py
space_view3d_copy_attributes.py
Copy Attributes: fix Copy Visual Scale
2023-10-17 16:32:29 +02:00
space_view3d_modifier_tools.py
system_blend_info.py
system_property_chart.py
