Testing add-ons only included in daily builds
Go to file
2023-02-07 14:46:48 +01:00
.gitea Gitea: add merge message templates 2023-01-30 23:55:27 +01:00
.github GitHub mirror: change Git URLs to point projects.blender.org instead of git.blender.org 2023-02-07 14:46:48 +01:00
add_mesh_clusters Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
automat Cleanup: quiet warnings registering add-ons 2021-07-30 17:38:13 +10:00
exact_edit Some minor spelling fixes. 2021-05-26 10:45:21 -04:00
io_scene_3ds Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
io_vector Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
lighting_hdri_shortcut Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
mocap Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
netrender Fix error registering netrender 2021-07-30 17:18:25 +10:00
np_station Some minor spelling fixes. 2021-05-26 10:45:21 -04:00
object_facemap_auto Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
object_fracture_crack Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
.arcconfig Fix .arcconfig not working with latest arcanist version 2020-03-01 22:41:31 +01:00
.gitignore Cleanup: redundant gitignore 2017-07-25 16:04:25 +10:00
add_dimension.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
animation_motion_trail.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
camera_overscan.py Update class names after api changes to Blender 2021-09-05 23:24:09 -04:00
development_class_viewer.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
development_ui_classes.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
io_export_after_effects.py After Effects export: fix crash when trying to export some meshes 2023-01-06 16:23:31 +01:00
io_import_sound_to_anim.py Cleanup: quiet warnings registering add-ons 2021-07-30 17:38:13 +10:00
io_scene_open_street_map.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
mesh_easy_lattice.py The apply_as parameter of modifier_apply was removed due to operator split. 2020-07-15 11:40:02 +03:00
mesh_selectbuffer.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
mesh_show_vgroup_weights.py Cleanup: remove <pep8 compliant> comment (no longer needed) 2022-06-07 21:12:54 +10:00
object_animrenderbake.py object_animrenderbake: suppress errors registering 2020-10-16 15:09:31 +11:00
object_batch_rename_datablocks.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
object_creaprim.py Fix error with object_creaprim handler being lost 2021-08-03 09:34:16 +10:00
object_mesh_versions.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
render_auto_save.py Cleanup: quiet warnings registering add-ons 2021-07-30 17:38:13 +10:00
render_cube_map.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
render_renderslot.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
render_time.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
render_to_print.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
space_clip_editor_autotracker.py Cleanup: quiet warnings registering add-ons 2021-07-30 17:38:13 +10:00
space_view3d_render_settings.py UI: Do not use term 'Subsurf' 2020-06-07 18:17:31 -04:00
system_keyboard_svg.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:52:13 +10:00
system_project_folder.py Update 'bl_info' use 'doc_url' instead of 'wiki_url' 2020-03-05 12:26:13 +11:00
