Add-ons bundled with Blender releases
Go to file
Thomas Barlow 6eb52267e4 FBX Export: Tidy up after numpy patches
Remove functions and imports that are now unused due to the previous numpy patches
Replace commented out code still using the array import with numpy equivalents
Reuse t_lvi array in UVs and Vertex Colors export
Remove trailing whitespace left in by another patch
This patch makes no changes to exported files
2023-03-13 11:17:59 +01:00
.gitea Gitea: use full URL for referencing pull requests 2023-03-07 13:24:58 +01:00
.github Docs: change Git URLs to point projects.blender.org instead of git.blender.org 2023-02-07 14:46:01 +01:00
add_camera_rigs Create Camera Rigs: fix DoF bone for 2D rig 2022-09-21 15:38:16 +02:00
add_curve_extra_objects D16656: Add Curve: Extra Objects - Add Curve Spiral Objects not conforming to 3D-Cursor Location 2022-12-03 17:36:19 +02:00
add_curve_sapling Fix T101985: Willow preset in tree gen addon not usable 2022-11-29 09:21:16 +05:30
add_mesh_BoltFactory Corrected resource leak when adding in EDIT mode 2022-02-14 17:55:45 +13:00
add_mesh_discombobulator File headers: use SPDX license identifiers 2022-02-11 16:34:06 +11:00
add_mesh_extra_objects Fix #104458: Extra Objects Single vert Mirror fails with Translation 2023-03-01 01:10:10 +01:00
add_mesh_geodesic_domes File headers: use SPDX license identifiers 2022-02-14 14:47:00 +11:00
amaranth Amaranth: Improve Open Node Source Image feature 2023-02-28 15:50:43 +01:00
animation_animall AnimAll: fix translations 2022-08-29 00:20:47 +02:00
ant_landscape Cleanup: fix typos 2022-10-14 19:52:42 +02:00
archimesh Fix #104467: Archimesh boolean doesn't work in 3.5 2023-03-06 14:51:23 +01:00
blender_id Official add-ons: fix printf-style format translation for i18n 2022-11-15 11:13:22 +01:00
btrace Fix T98902: Btracer Particle Trace is broken 2022-07-05 11:18:38 +02:00
curve_tools D16212: Curve Tools: Ensure nested paths in exported SVG look as expected. (Authored by Johan Althoff (teetow)) 2022-10-23 01:00:28 +03:00
greasepencil_tools greasepencil_tools: reduce scope of ssl import 2023-02-28 13:08:19 +11:00
io_anim_bvh Official add-ons: fix printf-style format translation for i18n 2022-11-15 11:13:22 +01:00
io_anim_nuke_chan Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_coat3D Cleanup: fix typos 2022-10-14 19:52:42 +02:00
io_curve_svg Official add-ons: fix printf-style format translation for i18n 2022-11-15 11:13:22 +01:00
io_export_dxf File headers: use SPDX license identifiers 2022-02-14 14:47:00 +11:00
io_import_dxf Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_import_palette Fix 104401: Import .ase files with swatch groups 2023-02-13 10:45:14 +01:00
io_mesh_atomic Atomic Blender: Get nodes with their types instead of names 2023-02-09 23:02:28 +01:00
io_mesh_ply PLY: Fix T103203 export with UVs 2022-12-14 18:16:38 +03:00
io_mesh_stl Cleanup: fix typos in blender addons 2022-08-09 19:24:13 +02:00
io_mesh_uv_layout UV Layout: replace deprecated bgl module 2022-09-21 20:38:06 -03:00
io_scene_fbx FBX Export: Tidy up after numpy patches 2023-03-13 11:17:59 +01:00
io_scene_gltf2 glTF importer: fix bad merge 2023-03-13 10:10:24 +01:00
io_scene_obj Cleanup: fix a few issues in UI messages 2023-02-23 16:42:37 +01:00
io_scene_x3d Fix T95455, T102384: Correct RGB color construction 2022-11-21 08:52:24 -03:00
io_shape_mdd Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
magic_uv Cleanup: fix a few issues in UI messages 2023-02-23 16:42:37 +01:00
materials_library_vx Cleanup: fix source comment typos 2022-03-15 18:31:13 +01:00
materials_utils Fix T104270: Error in materials_utils "unregister" function 2023-02-01 23:13:12 +11:00
measureit Cleanup: fix typos 2022-10-14 19:52:42 +02:00
mesh_inset Cleanup: fix typos 2022-10-14 19:52:42 +02:00
mesh_snap_utilities_line Fix T103356: 'NoneType' object has no attribute 'is_valid' 2022-12-20 12:02:43 -03:00
mesh_tiny_cad Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
mesh_tissue Cleanup: quiet warnings with descriptions ending with a '.' 2023-02-28 13:18:47 +11:00
mesh_tools Cleanup: fix typos 2022-10-14 19:52:42 +02:00
node_wrangler Node Wrangler: apply autopep8 formatting 2023-03-05 12:24:24 +01:00
object_carver Assign modifiers to variables instead of getting them by name 2023-02-27 21:51:16 +01:00
object_collection_manager Collection Manager: Fix "Add/Remove nested from selection". Task: T69577 2022-08-30 08:41:19 -04:00
object_fracture_cell Cleanup: fix various typos 2022-06-30 17:21:18 +02:00
object_print3d_utils Print 3D utils: make default exported file name translatable 2022-10-05 17:32:22 +02:00
object_scatter Scatter Objects: replace deprecated bgl module 2022-07-28 12:29:35 -03:00
pose_library pose_library: minor changes for shortcuts to show in menus 2023-01-11 19:30:26 +11:00
power_sequencer Cleanup: quiet float argument to in type warning 2023-02-28 13:21:57 +11:00
precision_drawing_tools Cleanup: fix typos 2022-10-14 19:52:42 +02:00
presets UI: Update deep grey community theme 2022-05-30 09:07:59 +02:00
render_copy_settings Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
render_povray Cleanup: trailing space 2023-01-31 15:47:58 +11:00
rigify Rigify: bump version. 2023-02-07 17:54:26 +02:00
space_view3d_brush_menus space_view3d_brush_menus: Improve brush icon support. 2022-04-10 01:10:26 -04:00
space_view3d_math_vis Math Vis: replace deprecated bgl module 2022-07-28 12:29:39 -03:00
space_view3d_pie_menus Fix #104431: Pie Menu Editor Switch: Can't switch to File Browser 2023-02-28 11:23:45 -03:00
space_view3d_spacebar_menu Spacebar Menu: remove old pose library from menu 2022-04-07 11:23:26 +02:00
space_view3d_stored_views Stored Views: Fix error when Lock 'To 3D Cursor' is active 2022-05-18 12:56:25 +02:00
storypencil Fix #104912: Storypencil - If Meta is selected allows TAB 2023-03-12 09:29:58 +01:00
sun_position Fix #104407: Sun Position: shader error when enabling 2023-02-13 13:39:44 -03:00
system_demo_mode Cleanup: fix various typos 2022-06-30 17:21:18 +02:00
ui_translate Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
viewport_vr_preview VR Scene Inspection: I18n: enable translation of UI messages 2023-02-27 08:39:51 +01:00
.gitignore add cycles folder to gitignore 2018-10-29 12:49:40 +01:00
add_curve_ivygen.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
animation_add_corrective_shape_key.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
bone_selection_sets.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
camera_turnaround.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
copy_global_transform.py Copy Global Transform: allow mirroring of pasted transforms 2023-03-10 12:30:21 +01:00
curve_assign_shapekey.py Curve Assign Shape Keys: replace deprecated bgl module 2022-07-21 11:03:42 -03:00
curve_simplify.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
depsgraph_debug.py Depsgraph Debug: add an operator to generate an SVG and open in browser. 2022-06-29 20:07:20 +03:00
development_edit_operator.py fix accidentally re-added license header 2022-06-13 23:03:01 +02:00
development_icon_get.py Fix T101708: Bug when joining nodes with thick lines 2022-10-20 13:15:36 +02:00
development_iskeyfree.py Cleanup: remove "Tweak" event type 2022-03-02 17:33:31 +11:00
io_anim_camera.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_export_paper_model.py File headers: use SPDX license identifiers 2022-02-11 16:34:06 +11:00
io_export_pc2.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
io_import_BrushSet.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
io_import_images_as_planes.py Fix T103359: Images as Planes: texture extension not applying 2022-12-23 11:51:26 -03:00
lighting_dynamic_sky.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
lighting_tri_lights.py File headers: use SPDX license identifiers 2022-02-11 16:34:06 +11:00
mesh_auto_mirror.py Assign modifiers to variables instead of getting them by name 2023-02-27 21:51:16 +01:00
mesh_bsurfaces.py Fix #104441: Bsurfaces: get modifiers with their type instead of name 2023-02-27 22:58:51 +01:00
mesh_f2.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
mesh_looptools.py Cleanup: fix typos 2022-10-14 19:52:42 +02:00
node_arrange.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
node_presets.py Fix T90845: Add missing geometry node type 2022-02-17 17:35:30 +11:00
object_boolean_tools.py Fix T98953: Typo in property name. 2022-06-17 11:33:32 +02:00
object_color_rules.py Object Color Rules: fix object selection 2022-06-10 09:57:29 +02:00
object_edit_linked.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
object_skinify.py Skinify: fix shape generation 2023-03-01 01:36:52 +01:00
paint_palette.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
real_snow.py Real Snow material update 2022-06-08 15:35:40 +02:00
render_freestyle_svg.py Cleanup: remove <pep8 compliant> comment 2022-06-03 11:50:32 +10:00
render_ui_animation_render.py Fix T101239: UI Animation Render: Attribute error when running in background 2022-09-21 10:18:38 +02:00
space_clip_editor_refine_solution.py Migrate to an updated motion tracking principal point property 2022-11-22 11:55:37 +01:00
space_view3d_3d_navigation.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
space_view3d_align_tools.py Align Tools: allow undo for all operators and presets for advanced 2022-10-20 13:15:43 +02:00
space_view3d_copy_attributes.py Fix #104036: Copy Attributes does not work on faces 2023-02-09 22:01:34 +01:00
space_view3d_modifier_tools.py Fix T103455: Modifier tools add-on don't support GPencil modifiers 2022-12-26 12:32:00 +05:30
system_blend_info.py File headers: use SPDX license identifiers 2022-02-11 16:05:07 +11:00
system_property_chart.py system_property_chart: support custom properties 2022-07-22 15:59:27 +10:00
