.gitea
Gitea: use full URL for referencing pull requests
2023-03-07 13:24:58 +01:00 |
.github
Docs: change Git URLs to point projects.blender.org instead of git.blender.org
2023-02-07 14:46:01 +01:00 |
add_camera_rigs
License headers: use SPDX-FileCopyrightText for all addons
2023-06-15 16:54:05 +10:00 |
add_curve_extra_objects
add_curve_sapling
add_mesh_BoltFactory
Merge branch 'blender-v3.6-release'
2023-06-19 21:48:14 -04:00 |
add_mesh_discombobulator
add_mesh_extra_objects
add_mesh_geodesic_domes
amaranth
Amaranth: remove render output Z check, since this option was removed
2023-07-04 19:54:15 +02:00 |
animation_animall
ant_landscape
archimesh
blender_id
btrace
curve_tools
greasepencil_tools
io_anim_bvh
io_anim_nuke_chan
io_coat3D
io_curve_svg
io_export_dxf
io_import_dxf
io_import_palette
io_mesh_3mf
add io_mesh_3mf addon
2023-10-12 22:09:07 -07:00 |
io_mesh_atomic
io_mesh_stl
io_mesh_uv_layout
io_scene_3ds
Export_3ds: Fixed axis flip in target animation
2023-07-16 14:51:01 +02:00 |
io_scene_fbx
Fix #104737: FBX: Materials missing from linked duplicates
2023-07-06 10:15:54 +02:00 |
io_scene_gltf2
glTF exporter: fix crash when user try to merge identical tracks
2023-07-16 08:08:44 +02:00 |
io_scene_x3d
Import_x3d: Fixed mesh flat/smooth shading
2023-06-20 23:05:52 +02:00 |
io_shape_mdd
magic_uv
Fix #104729. Added missing OperatorStrokeElement keywords.
2023-07-02 12:29:45 +02:00 |
materials_library_vx
materials_utils
measureit
mesh_inset
mesh_snap_utilities_line
mesh_tiny_cad
mesh_tissue
mesh_tools
node_wrangler
Fix #104573: node wrangler no matching images found error
2023-06-27 10:14:11 +02:00 |
object_carver
object_collection_manager
2023-06-22 02:17:38 -04:00 |
object_fracture_cell
object_print3d_utils
object_scatter
pose_library
power_sequencer
precision_drawing_tools
presets
Lights: update for removal of unused Blender Internal properties
2023-07-05 18:23:51 +02:00 |
render_copy_settings
render_povray
rigify
space_view3d_brush_menus
space_view3d_math_vis
space_view3d_pie_menus
space_view3d_spacebar_menu
space_view3d_stored_views
storypencil
sun_position
system_demo_mode
ui_translate
vdm_brush_baker
viewport_vr_preview
.gitignore
add cycles folder to gitignore
2018-10-29 12:49:40 +01:00 |
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
camera_turnaround.py
copy_global_transform.py
curve_assign_shapekey.py
curve_simplify.py
depsgraph_debug.py
development_edit_operator.py
development_icon_get.py
development_iskeyfree.py
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
io_import_images_as_planes.py
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py
mesh_f2.py
mesh_looptools.py
node_arrange.py
node_presets.py
object_boolean_tools.py
object_color_rules.py
object_edit_linked.py
object_skinify.py
paint_palette.py
real_snow.py
render_freestyle_svg.py
render_ui_animation_render.py
space_clip_editor_refine_solution.py
space_view3d_3d_navigation.py
space_view3d_align_tools.py
space_view3d_copy_attributes.py
space_view3d_modifier_tools.py
system_blend_info.py
system_property_chart.py
