.gitea
Gitea: use full URL for referencing pull requests
2023-03-07 13:24:58 +01:00 |
.github
Docs: change Git URLs to point projects.blender.org instead of git.blender.org
2023-02-07 14:46:01 +01:00 |
add_camera_rigs
Create Camera Rigs: fix DoF bone for 2D rig
2022-09-21 15:38:16 +02:00 |
add_curve_extra_objects
D16656: Add Curve: Extra Objects - Add Curve Spiral Objects not conforming to 3D-Cursor Location
2022-12-03 17:36:19 +02:00 |
add_curve_sapling
Fix T101985: Willow preset in tree gen addon not usable
2022-11-29 09:21:16 +05:30 |
add_mesh_BoltFactory
Corrected resource leak when adding in EDIT mode
2022-02-14 17:55:45 +13:00 |
add_mesh_discombobulator
File headers: use SPDX license identifiers
2022-02-11 16:34:06 +11:00 |
add_mesh_extra_objects
Fix #104458: Extra Objects Single vert Mirror fails with Translation
2023-03-01 01:10:10 +01:00 |
add_mesh_geodesic_domes
2022-02-14 14:47:00 +11:00 |
amaranth
Amaranth: Improve Open Node Source Image feature
2023-02-28 15:50:43 +01:00 |
animation_animall
Animall: update French translations
2023-04-14 01:55:10 +02:00 |
ant_landscape
Cleanup: fix typos
2022-10-14 19:52:42 +02:00 |
archimesh
Update scripts for changes to gpu.shader.from_builtin
2023-05-23 15:55:18 +10:00 |
blender_id
Cleanup: UI messages fixes and tweaks.
2023-04-17 11:41:34 +02:00 |
btrace
Fix T98902: Btracer Particle Trace is broken
2022-07-05 11:18:38 +02:00 |
curve_tools
greasepencil_tools
GPencil Tools: Mirror flip and Canvas rotate Fixes
2023-05-28 00:13:53 +02:00 |
io_anim_bvh
Fix #104510: X3D & BVH import error with Python 3.11
2023-04-06 19:06:56 +10:00 |
io_anim_nuke_chan
Cleanup: remove <pep8 compliant> comment
2022-06-03 11:50:32 +10:00 |
io_coat3D
Cleanup: fix typos
io_curve_svg
Official add-ons: fix printf-style format translation for i18n
2022-11-15 11:13:22 +01:00 |
io_export_dxf
io_export_dxf: Added DXF suffix to menu description
2023-05-26 11:29:42 +02:00 |
io_import_dxf
io_import_dxf: Added DXF to menu description
2023-05-26 11:32:05 +02:00 |
io_import_palette
Fix 104401: Import .ase files with swatch groups
2023-02-13 10:45:14 +01:00 |
io_mesh_atomic
io_mesh_atomic: code polishing
2023-05-19 11:35:05 +02:00 |
io_mesh_ply
Cleanup: Remove setting polygon loop total
2023-04-12 08:46:40 -04:00 |
io_mesh_stl
Cleanup: fix typos in blender addons
2022-08-09 19:24:13 +02:00 |
io_mesh_uv_layout
io_scene_3ds
Export_3ds: Fixed key error if object has an unselected parent
2023-05-27 01:45:31 +02:00 |
io_scene_fbx
Update add-ons for removed Mesh.calc_normals()
2023-05-23 13:04:12 +10:00 |
io_scene_gltf2
Merge branch 'blender-v3.6-release'
2023-05-24 09:10:49 +02:00 |
io_scene_obj
io_scene_x3d
io_shape_mdd
magic_uv
Update scripts to account for removal of the context override to bpy.ops
2023-05-23 14:56:22 +10:00 |
materials_library_vx
Cleanup: fix source comment typos
2022-03-15 18:31:13 +01:00 |
materials_utils
Fix T104270: Error in materials_utils "unregister" function
2023-02-01 23:13:12 +11:00 |
measureit
mesh_inset
mesh_snap_utilities_line
Remove deprecated 2D_/3D_ prefix
2023-05-23 16:00:43 +10:00 |
mesh_tiny_cad
mesh_tissue
mesh_tools
Cleanup: fix typos
node_wrangler
Node Wrangler: Remove deprecated useless width_hidden property
2023-05-18 13:38:14 -04:00 |
object_carver
Update use of blf.size to remove use of deprecated dpi argument
2023-05-23 12:23:52 +10:00 |
object_collection_manager
object_fracture_cell
Cleanup: fix various typos
2022-06-30 17:21:18 +02:00 |
object_print3d_utils
3D-Print Export: less agressive filename sanitation
2023-03-29 20:06:06 +04:00 |
object_scatter
pose_library
2023-05-30 19:31:51 +02:00 |
power_sequencer
precision_drawing_tools
presets
Sun Position: capitalize preset names
2023-04-14 18:56:31 +02:00 |
render_copy_settings
render_povray
2023-05-25 15:17:56 +10:00 |
rigify
Rigify: bump version.
2023-02-07 17:54:26 +02:00 |
space_view3d_brush_menus
space_view3d_brush_menus: Improve brush icon support.
2022-04-10 01:10:26 -04:00 |
space_view3d_math_vis
space_view3d_pie_menus
Fix #104431: Pie Menu Editor Switch: Can't switch to File Browser
2023-02-28 11:23:45 -03:00 |
space_view3d_spacebar_menu
Spacebar Menu: remove old pose library from menu
2022-04-07 11:23:26 +02:00 |
space_view3d_stored_views
storypencil
sun_position
system_demo_mode
system_demo_mode: minor usability improvements
2023-05-25 10:02:22 +10:00 |
ui_translate
Minor update to ui_translate addons to cleanup output.
2023-04-17 14:34:56 +02:00 |
vdm_brush_baker
VDM brush baker
2023-05-12 15:42:10 +02:00 |
viewport_vr_preview
VR Scene Inspection: I18n: enable translation of UI messages
2023-02-27 08:39:51 +01:00 |
.gitignore
add cycles folder to gitignore
2018-10-29 12:49:40 +01:00 |
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
2022-02-11 16:05:07 +11:00 |
camera_turnaround.py
copy_global_transform.py
Copy Global Transform: add tracker URL
2023-04-11 17:25:20 +02:00 |
curve_assign_shapekey.py
curve_simplify.py
depsgraph_debug.py
Added a location info line to indicate where buttons are.
2023-03-27 15:34:30 +02:00 |
development_edit_operator.py
fix accidentally re-added license header
2022-06-13 23:03:01 +02:00 |
development_icon_get.py
Fix T101708: Bug when joining nodes with thick lines
2022-10-20 13:15:36 +02:00 |
development_iskeyfree.py
Cleanup: remove "Tweak" event type
2022-03-02 17:33:31 +11:00 |
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
io_import_images_as_planes.py
Import Images: I18n: enable translation of one message
2023-05-30 19:30:23 +02:00 |
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
Assign modifiers to variables instead of getting them by name
2023-02-27 21:51:16 +01:00 |
mesh_bsurfaces.py
mesh_f2.py
mesh_looptools.py
Cleanup: fix typos
node_arrange.py
node_presets.py
Fix T90845: Add missing geometry node type
2022-02-17 17:35:30 +11:00 |
object_boolean_tools.py
Fix T98953: Typo in property name.
2022-06-17 11:33:32 +02:00 |
object_color_rules.py
Object Color Rules: fix object selection
2022-06-10 09:57:29 +02:00 |
object_edit_linked.py
object_skinify.py
Skinify: fix shape generation
2023-03-01 01:36:52 +01:00 |
paint_palette.py
real_snow.py
Real Snow material update
2022-06-08 15:35:40 +02:00 |
render_freestyle_svg.py
render_ui_animation_render.py
Fix T101239: UI Animation Render: Attribute error when running in background
2022-09-21 10:18:38 +02:00 |
space_clip_editor_refine_solution.py
Migrate to an updated motion tracking principal point property
2022-11-22 11:55:37 +01:00 |
space_view3d_3d_navigation.py
space_view3d_align_tools.py
Align Tools: allow undo for all operators and presets for advanced
2022-10-20 13:15:43 +02:00 |
space_view3d_copy_attributes.py
Fix #104036: Copy Attributes does not work on faces
2023-02-09 22:01:34 +01:00 |
space_view3d_modifier_tools.py
Fix T103455: Modifier tools add-on don't support GPencil modifiers
2022-12-26 12:32:00 +05:30 |
system_blend_info.py
system_property_chart.py
system_property_chart: support custom properties
2022-07-22 15:59:27 +10:00 |
