This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
02baf30e55b1159bb9e347998caaa8fac12afb81
file path where library is read from. In Outliner, choose new view mode "Libraries". A ctrl+click on the library name then allows to change the file name or path. Note that when you change the file name, nothing is being re-read or re-linked. Only after saving the .blend file and reading it back the new library is used. This feature allows to cleanup library usage. You can make files relative, or reorganize a project. Just keep in mind that you cannot use this feature to fix .blend files that link to non-existing other files. That because the lost data is actually not read at all, so cannot be saved either. Currently, library errors are only printed in the console... quite important to keep track of when using Libraries. Implementation note: this Outliner view mode can become expanded to a full "Database view", showing something similar as SHIFT+F4 databrowse does now.
Welcome to the fun world of open source. For instructions on building and installing Blender, please see the file named INSTALL. ---------------------.Blanguages and the .blender directory--------------------- The .blender directory holds various data files for Blender. In the 2.28a release those are the .Blanguages file containing a list of translations, the translations themselves and a default ttf font. Blender checks for the presence of this directory in several locations: - the current directory - your home directory - On OSX, the blender bundle is also checked - On Windows, the installation dir is checked. If you get a 'File ".Blanguages" not found' warning, try to copy the .blender dir to one of these locations (your home directory being recommended). -------------------------------------Links-------------------------------------- Getting Involved: http://www.blender.org/docs/get_involved.html Community: http://www.blender3d.org/Community/ Main blender development site: http://www.blender.org/ The Blender project homepage: http://projects.blender.org/projects/bf-blender/ Documentation: http://www.blender.org/modules.php?op=modload&name=documentation&file=index Bug tracker: http://projects.blender.org/tracker/?atid=125&group_id=9&func=browse Feature request tracker: http://projects.blender.org/tracker/?atid=128&group_id=9&func=browse
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
