This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
03df72ee4e7e7f9893df73de426cdc3af1c7a676
This change makes it possible to add implementation of common
C++ methods for DNA structures which helps ensuring unsafe
operations like shallow copy are done explicitly.
For example, creating a shallow copy used to be:
Object temp_object = *input_object;
In the C++ context it was seen like the temp_object is
properly decoupled from the input object, while in the
reality is it not. Now this code becomes:
Object temp_object = blender::dna::shallow_copy(*input_object);
The copy and move constructor and assignment operators are
now explicitly disabled.
Other than a more explicit resource management this change
also solves a lot of warnings generated by the implicitly
defined copy constructors w.r.t dealing with deprecated fields.
These warnings were generated by Apple Clang when a shallow
object copy was created via implicitly defined copy constructor.
In order to enable C++ methods for DNA structures a newly added
macro `DNA_DEFINE_CXX_METHODS()` is to be used:
tpyedef struct Object {
DNA_DEFINE_CXX_METHODS(Object)
} Object;
For the shallow copy use `blender::dna::shallow_copy()`.
The implementation of the memcpy is hidden via an internal DNA
function to avoid pulling `string.h` into every DNA header.
This means that the solution does not affect on the headers
dependencies.
Ideally `DNA_shallow_copy` would be defined in a more explicit
header, but don;t think we have a suitable one already. Maybe
we can introduce `DNA_access.h` ?
Differential Revision: https://developer.blender.org/D14427
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
