This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
05952aa94d33eeb504fa63618ba35c2bcc8bd19b
For copy-on-write, we want to share attribute arrays between meshes where possible. Mutable pointers like `Mesh.mvert` make that difficult by making ownership vague. They also make code more complex by adding redundancy. The simplest solution is just removing them and retrieving layers from `CustomData` as needed. Similar changes have already been applied to curves and point clouds (e9f82d3dc7,410a6efb74). Removing use of the pointers generally makes code more obvious and more reusable. Mesh data is now accessed with a C++ API (`Mesh::edges()` or `Mesh::edges_for_write()`), and a C API (`BKE_mesh_edges(mesh)`). The CoW changes this commit makes possible are described in T95845 and T95842, and started in D14139 and D14140. The change also simplifies the ongoing mesh struct-of-array refactors from T95965. **RNA/Python Access Performance** Theoretically, accessing mesh elements with the RNA API may become slower, since the layer needs to be found on every random access. However, overhead is already high enough that this doesn't make a noticible differenc, and performance is actually improved in some cases. Random access can be up to 10% faster, but other situations might be a bit slower. Generally using `foreach_get/set` are the best way to improve performance. See the differential revision for more discussion about Python performance. Cycles has been updated to use raw pointers and the internal Blender mesh types, mostly because there is no sense in having this overhead when it's already compiled with Blender. In my tests this roughly halves the Cycles mesh creation time (0.19s to 0.10s for a 1 million face grid). Differential Revision: https://developer.blender.org/D15488
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
