This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Jacques Lucke 05b38ecc78 Curves: support deforming curves on surface
Curves that are attached to a surface can now follow the surface when
it is modified using shape keys or modifiers (but not when the original
surface is deformed in edit or sculpt mode).
The surface is allowed to be changed in any way that keeps uv maps
intact. So deformation is allowed, but also some topology changes like
subdivision.
The following features are added:
* A new `Deform Curves on Surface` node, which deforms curves with
  attachment information based on the surface object and uv map set
  in the properties panel.
* A new `Add Rest Position` checkbox in the shape keys panel. When checked,
  a new `rest_position` vector attribute is added to the mesh before shape
  keys and modifiers are applied. This is necessary to support proper
  deformation of the curves, but can also be used for other purposes.
* The `Add > Curve > Empty Hair` operator now sets up a simple geometry
  nodes setup that deforms the hair. It also makes sure that the rest
  position attribute is added to the surface.
* A new `Object (Attach Curves to Surface)` operator in the `Set Parent To`
  (ctrl+P) menu, which attaches existing curves to the surface and sets the
  surface object as parent.
Limitations:
* Sculpting the procedurally deformed curves will be implemented separately.
* The `Deform Curves on Surface` node is not generic and can only be used
  for one specific purpose currently. We plan to generalize this more in the
  future by adding support by exposing more inputs and/or by turning it into
  a node group.
Differential Revision: https://developer.blender.org/D14864
2022-07-08 14:47:10 +02:00
2021-10-23 10:49:51 +05:30
2022-06-29 10:19:02 +10:00
2022-07-05 14:34:09 +10:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
2022-01-25 09:19:03 -07:00
2022-06-28 15:56:16 +02:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/05b38ecc7835b32a9f3aedf36ead4b3e41ec6ca4/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
