This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Benoit Bolsee 0ab2f675c3 Fix bug in Mathutil with matrix/matrix and matrix/vector multiplication order.
MathUtil matrix type follows Blender convention of column
major storage.  This means that the elements on one column
are contiguous in memory. Vectors are one dimensional
arrays that can be considered in row or in column but
the Blender convention is column so vector should only
be considered as row. This means that the only logical
multiplication operation between matrix and vector is
matrix * vector.
This convention is respected in all parts of MathUtil
except in matrix/matrix and matrix/vector multiplication
where the row major convention is assumed, which in the
and is equivalent to reversing the order of multiplication.
This is clearly a bug and must be corrected but the side
effect is that it will break all scripts using these
operations. Script writers who care about the correctness
of the matrix operations have already implemented work around:
1) change order of matrix/vector multiplication.
vec2 = vec1 * mat1
This must be changed to the normal order:
vec2 = mat1 * vec1
2) change order of matrix/matrix multiplication
(with matl a local transform in matw reference)
mat3 = matl * matw
mat3 = matw * matl
3) transpose before an after the multiplication
matl.transpose()
matw.transpose()
mat3 = matw * matl
mat3.transpose()
This must be changed to:
mat3 = matw * matl;
2009-09-07 22:26:23 +00:00
2009-09-01 23:43:00 +00:00
2009-09-07 18:44:01 +00:00
Welcome to the fun world of open source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/community/get-involved
Community:
http://www.blender.org/Community
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender
Documentation:
http://www.blender.org/education-help
Bug tracker:
http://www.blender.org/development/report-a-bug
Feature request tracker:
http://wiki.blender.org/index.php/Requests
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
