This repository has been archived on 2023-10-09 . You can view files and clone it, but cannot push or open issues or pull requests.
					0b7744f4da666bccf2005ad0d0e77c5ddc73bfd5
	Fix issue described in T87678, which was partially a bug and partially change in intended(at least as far as I can tell) behaior. Function `evaluate_seq_frame_gen` that was partially responsible for filtering strips in stack for rendering wasn't working correctly. Intended functionality seems to be removing all effect inputs from stack as it is unlikely that user would want these to be blended in. However there was logic to exclude effects placed into same input, which because of weak implementation caused, that any effect input, that is effect as well will be considered to be part of stack to be blended in. This bug was apparently used to produce effects like glow over original image. Even though this is originally unintended, I have kept this logic, but I have made it explicit. Another change is request made in T87678 to make it possible to keep effect inputs as part of stack when they are placed above the effect, which would imply that blending is intended. This change is again explicitly defined. Whole implementation has been refactored, so logic is consolidated and code should be as explicit as possible and more readable. `must_render_strip function` may be still quite hard to read, not sure if I can make it nicer. Last change is for remove gaps feature code - it used same rendering code, which may be reason why its logic was split in first place. Now it uses sequencer iterator, which will definitely be faster than original code, but I could have used `LISTBASE_FOREACH` in this case. Reviewed By: sergey Differential Revision: https://developer.blender.org/D11301
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
					Languages
									C
								67.4%
									C++
								23.4%
									Python
								6.1%
									CMake
								1.5%
									GLSL
								1.1%
									Other
								0.4%
