This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
169a87cb0b51b29a01274db6b106e9a8d0cca8ac
Keyframes are now prepared for drawing by being added to a binary-tree structure instead of using insertion-sort on a Double-Linked List. This gives rather significant improvements on a few bad cases (*). I've implemented a basic Red-Black Tree whose nodes/data-structures can also be used as a simple Double-Linked List (ListBase) for this purpose. The implementation of this tree currently does not have support for removing individual nodes, since such capabilities aren't needed yet. Stats (using keyframes from an imported .bvh animation file): * When only the keyframes are drawn (i.e. long keyframes are not identified), the time needed to draw the DopeSheet region 10 times went down from 4000ms to about 300ms. * When long keyframes are considered as well, the same test has gone from 6000ms to 3000ms. There is still a bottleneck there that I haven't been able to remove yet (an attempt at this made the runtimes go through the roof - 32000 ms for the test done here). Assorted Notes: * Added missing headers for some files * Fixed profiling flags for mingw. There was an extra space which prevented the sound-code from compiling.
Welcome to the fun world of open source. For instructions on building and installing Blender, please see the file named INSTALL. ---------------------.Blanguages and the .blender directory--------------------- The .blender directory holds various data files for Blender. In the 2.28a release those are the .Blanguages file containing a list of translations, the translations themselves and a default ttf font. Blender checks for the presence of this directory in several locations: - the current directory - your home directory - On OSX, the blender bundle is also checked - On Windows, the installation dir is checked. If you get a 'File ".Blanguages" not found' warning, try to copy the .blender dir to one of these locations (your home directory being recommended). -------------------------------------Links-------------------------------------- Getting Involved: http://www.blender.org/community/get-involved Community: http://www.blender.org/Community Main blender development site: http://www.blender.org The Blender project homepage: http://projects.blender.org/projects/bf-blender Documentation: http://www.blender.org/education-help Bug tracker: http://www.blender.org/development/report-a-bug Feature request tracker: http://wiki.blender.org/index.php/Requests
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
