This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Sergey Sharybin 27baa34ba4 Fix #35369: Crop node or FileOutput node bug.
Issue was caused by file output node actually,
The thing here is, compositor output does have fixed
resolution and we could predict how to map coordinates
for border and cropping in that case.
But viewers and file output nodes are currently totally
depending on an input resolution. Could not see how
border could be applied reliably in this cases.
Disabling border option for file output node, so
now it shall behave the same way as it was before.
Discovered issues when using cropping to render border,
namely there's an offset in viewer nodes and previews,
but this is separate issue i guess (file output seems
to work fine). Will revisit this issue in next days.
2013-05-17 13:02:03 +00:00
2013-05-16 03:55:47 +00:00
2010-10-13 14:44:22 +00:00
S
Archive of Blender with old branches
823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
