This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Daniel Genrich 286c2ca80b Smoke:
* cache for low res (deactivating high res for now)
* new way of view3d rendering of smoke (no longer 3 axes) -using 3dtexture now (introduced into gpu/intern)
* introducing LZO and LZMA libs into extern (makefiles missing for now)
* reducing memory usage after simulating for the frame ended (freeing temporary buffers)
* splitting smoke into 2 modifier for the cache-sake (it cannot handle more than 1 cache on the same modifier-index)
* no color on gui anymore
* fixing non-power-of-2 resolutions (hopefully)
* fixing select-deselect of domain drawing bug
* fixing drawobject.c coding style (making Ton happy) ;-)
HINT #1: If scons doesn't work -> cmakefiles are up-to-date, couldn't test scons (but i tried to mantain them, too)
CODERS HINT #1: we really need a way to disable adding all modifiers through "Add Modifiers" dropdown!
WARNING #1: before applying this commit, deactivate your SMOKE DOMAIN in your old files and save them then. You can open them then savely after that.
WARNING #2: File and cache format of smoke can be changed, this is not final!
2009-08-20 00:33:59 +00:00
2009-08-17 11:39:34 +00:00
Welcome to the fun world of open source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/community/get-involved
Community:
http://www.blender.org/Community
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender
Documentation:
http://www.blender.org/education-help
Bug tracker:
http://www.blender.org/development/report-a-bug
Feature request tracker:
http://wiki.blender.org/index.php/Requests
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
