This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
2aea765d6eebd0dccf355c83ed9cb0eac5965072
The tracker description: "This patch fixes this bug: http://projects.blender.org/tracker/index.php?func=detail&aid=25487&group_id=9&atid=306 This was accomplished by making sure the KX_GameObject's object color gets set during the conversion process in the method gameobject_from_blenderobject. Otherwise all the values for object color default to 0. The reason adding an IPO worked as a work around is because it set the object color." The bug report mentioned is bug [#25487] "BGE: Object Color only works when it has a keyed frame"
Archive of Blender with old branches
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
