This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
2c6a82dd0a9178efcaee0c3f8bbf3e5120a3dcaa
Fix #34948, bug in Cycles node groups. The proxy node maps used to identify external connections of node group nodes were having name clashes with input/output sockets of the same name, leading to invalid cyclic connections in the cycles shader graph that were subsequently removed (prints warnings in terminal). Solution is to use two separate maps for inputs and outputs so group node sockets can safely use the same identifier.
Archive of Blender with old branches
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
