This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
3ffb695b10bd85f7cd431f6144dbc2c427a365ee
Blended shape keys can now be displayed & edited in edit mode. This is much like showing an armature modifier in edit mode, and shape keys now are a applied as a virtual modifier (for mesh & lattice only, curve doesn't fit in the stack well due to tilt). The main thing missing still is being able to switch between the active shape key in edit mode, that's more complicated.. but the weights of other shapes can be edited while in edit mode. One thing to be careful about is that this does automatic crazyspace correction, which means that if you edit a shape key with a low value, the actual vertices will be moved to correct for that and actually move a (potentially much) longer distance. Also includes some UI tweaks, mainly placing some buttons horizontally since the vertical list was getting too long.
Fix #19574: winbuildinfo.h error when compiling with cmake on windows. I've now removed winbuildinfo.h code and let scons on window just set environment vars like other operating systems. Note that cmake still doesn't get the date information on windows, implementation is missing for this.
Welcome to the fun world of open source. For instructions on building and installing Blender, please see the file named INSTALL. ---------------------.Blanguages and the .blender directory--------------------- The .blender directory holds various data files for Blender. In the 2.28a release those are the .Blanguages file containing a list of translations, the translations themselves and a default ttf font. Blender checks for the presence of this directory in several locations: - the current directory - your home directory - On OSX, the blender bundle is also checked - On Windows, the installation dir is checked. If you get a 'File ".Blanguages" not found' warning, try to copy the .blender dir to one of these locations (your home directory being recommended). -------------------------------------Links-------------------------------------- Getting Involved: http://www.blender.org/community/get-involved Community: http://www.blender.org/Community Main blender development site: http://www.blender.org The Blender project homepage: http://projects.blender.org/projects/bf-blender Documentation: http://www.blender.org/education-help Bug tracker: http://www.blender.org/development/report-a-bug Feature request tracker: http://wiki.blender.org/index.php/Requests
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
