This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Dave Pagurek 468f2ccc0e GPencil: Add more types of stroke extensions when filling
The motivation for this change: while working on an animation recently, I found that there are some gaps that won't close easily via stroke extension or leak size checking. In D14698, I attempted to address this by changing the algorithm of the raster-space flood fill. This patch attempts to address the same issue in vector space by adding two new cases where stroke extensions are added, as suggested by @frogstomp:
  # **Points of high curvature:** when the curvature at a point is high enough that it's hard to visually distinguish between it and an endpoint, add a stroke extension out along the normal (pointing in the opposite direction of the stroke's acceleration.) This addresses cases where technically the endpoint points up, but there's a sharp corner right below it that should extend to connect.
  # **Stroke endpoints within a radius**: when two endpoints are close together, regardless of the angle they make, connect them if they are within a radius. This addresses cases like where the two endpoints have effectively parallel tangents, so extensions won't close the gap.
Reviewed By: antoniov, mendio, frogstomp
Differential Revision: https://developer.blender.org/D14809
2022-09-17 12:30:13 +02:00
2021-10-23 10:49:51 +05:30
2022-09-15 22:30:47 -04:00
2022-08-15 16:10:29 +02:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
2022-01-25 09:19:03 -07:00
2022-06-28 15:56:16 +02:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/468f2ccc0ecbcb368aab950c61c2cc0bc95b27e1/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
