This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Himanshi Kalra 4a02b9ffeb Regression Testing: Running tests based on blend files
Runs tests based on blend files with minimum python interaction.
Developed as part of GSoC 2021 - Regression Testing of Geometry Nodes.
Earlier, tests were built from scratch by adding a modifier/operation
from the Python API.
Now, tests can also be created inside blender and are compared using
Python script.
Features: Automatically adding expected object if it doesn't exist.
This patch adds tests for the following Geometry Nodes category:
* Curves
* Geometry
* Mesh
* Points
The implemented UML diagram for refactoring of mesh test framework.
{F10225906}
Technical Changes:
SpecMeshTest: It adds the modifier/operation based on the Spec provided.
BlendFileTest: It applies already existing modifier/operation from the blend file.
Test folders hierarchy with tests. This folder should be extracted to `lib\tests\modeling`
{F10240651}
Note: The `geometry_nodes` folder might lie under another `geometry_nodes` folder while extracting, please double check. Use the inner-most one.
The hierarchy should be:
-`lib\tests\modeling\geometry_nodes\mesh`
-`lib\tests\modeling\geometry_nodes\points`
and so on.
* From `ctest` the tests should be run as `ctest -R geo_node -C [Configuration]` on Windows.
* Each single test can be run with its entire name e..g `ctest -R geo_node_geometry_join_geometry`.(just an example). Run `ctest -N -R geo_node` to see all tests.
* From blender, the tests can be run `blender -b path\to\blend\file --python path\to\geo_node_test.py`
Reviewed By: zazizizou, JacquesLucke
Differential Revision: https://developer.blender.org/D11611
2021-07-27 21:01:15 +05:30
2021-07-22 20:13:14 -04:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/4a02b9ffeb018ced11768ca99935fda5fa5f7da0/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
