This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Ton Roosendaal 4ad59e30a0 New: Write Protection for transform values.
You now can set, in NKEY Transform Properties Panel, per XYZ rot/loc/size,
a protection for Transform tools to not change these values anymore.
This now works for Objects or for Bones in PoseMode.
Usage is especially for character animation, to give Bones in a Pose
defaults for rotation axes, so you don't have to worry about the correct
limitations (or setup complex IK limits).
Of course, this feature doesn't influence the animation system.
As an extra also the Transform Widgets then draw less handles. Note this
is based on the actual locked value, and depends still on Manipulator
orientation whether it can be used really.
Implementation warning: I had to remove the 'return' in the middle of the
editobject.c compatible_eul() call. It now makes nice compatible eulers
when they're simple (single axis rotations). Unfortunately there was no
note in the code why it was ever removed...
ALso: fix for crash in using Crease Transform and Mirror modifier.
2005-10-29 20:08:25 +00:00
2005-01-05 10:27:48 +00:00
2005-06-06 12:18:44 +00:00
2003-09-08 12:13:54 +00:00
2005-10-10 20:13:18 +00:00
2004-08-24 02:51:07 +00:00
Welcome to the fun world of open source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/docs/get_involved.html
Community:
http://www.blender3d.org/Community/
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender/
Documentation:
http://www.blender.org/modules.php?op=modload&name=documentation&file=index
Bug tracker:
http://projects.blender.org/tracker/?atid=125&group_id=9&func=browse
Feature request tracker:
http://projects.blender.org/tracker/?atid=128&group_id=9&func=browse
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
