This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
5dac88dc58e362a58dcd7fb6df1537fb9949b4a7
In outliner, the icons sometimes were drawing too large or too small. Same happened in NLA, Action, Image window etc. And it happened for "International fonts" when set to use 'texture drawing'. Reason: the API call for setting icon size BIF_icon_set_aspect() was not used consistantly. Sometimes it was set, sometimes not. And even worse, for every icon drawn in UI buttons, the icon lookup had to be done twice because of the aspect function. Solved it by removing this call, and adding a new function: BIF_icon_draw_aspect() The old BIF_icon_draw() call now draws with aspect 1.0 always. The icons code already had optimal checking for changed sizes, zo a change in aspect won't result in much cpu overhead. Plus it saves calling icons lookup code, which will make it all a bit faster. Andrea: I've added this aspect function a long while ago, I think you also like it better how it is now? Please check!
Welcome to the fun world of open source. For instructions on building and installing Blender, please see the file named INSTALL. ---------------------.Blanguages and the .blender directory--------------------- The .blender directory holds various data files for Blender. In the 2.28a release those are the .Blanguages file containing a list of translations, the translations themselves and a default ttf font. Blender checks for the presence of this directory in several locations: - the current directory - your home directory - On OSX, the blender bundle is also checked - On Windows, the installation dir is checked. If you get a 'File ".Blanguages" not found' warning, try to copy the .blender dir to one of these locations (your home directory being recommended). -------------------------------------Links-------------------------------------- Getting Involved: http://www.blender.org/docs/get_involved.html Community: http://www.blender3d.org/Community/ Main blender development site: http://www.blender.org/ The Blender project homepage: http://projects.blender.org/projects/bf-blender/ Documentation: http://www.blender.org/modules.php?op=modload&name=documentation&file=index Bug tracker: http://projects.blender.org/tracker/?atid=125&group_id=9&func=browse Feature request tracker: http://projects.blender.org/tracker/?atid=128&group_id=9&func=browse
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
