This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Michel Selten 70a4ead0ae SCons updates
* Blender static now links. By default this option is disabled on all
  platforms. Simply set the option in config.opts to 'true'.
* Added the following flags to config.opts:
  - HOST_CC.    This is the C compiler for the host platform. This value is the
                same as TARGET_CC when not cross compiling.
  - HOST_CXX.   This is the C++ compiler for the host platform. This value is
                the same as TARGET_CXX when not cross compiling.
  - TARGET_CC.  This is the C compiler for the target platform.
  - TARGET_CXX. This is the C++ compiler for the target platform.
  - TARGET_AR.  This is the linker command for linking libraries.
  - PATH        This is the standard search path
  All SConscript files have been updated to reflect these changes. Now it's
  possible to change only the root SConstruct file, and all compiler specific
  variables are passed automatically to all SConscript files. Of course, this
  does not apply to makesdna because there the host and target platform is
  different from all other libraries.
  To pass a variable that applies to all platforms, all we now have to do is
  set the correct value in library_env
Note: as usual, to get the latest options in the config.opts file, first
      remove your version.
2004-02-29 21:40:48 +00:00
2004-01-02 23:35:21 +00:00
2003-09-08 12:13:54 +00:00
2002-11-15 06:57:59 +00:00
Welcome to the fun world of open-source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/docs/get_involved.html
Community:
http://www.blender3d.org/Community/
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender/
Documentation:
http://www.blender.org/modules.php?op=modload&name=documentation&file=index
Bug tracker:
http://projects.blender.org/tracker/?atid=125&group_id=9&func=browse
Feature request tracker:
http://projects.blender.org/tracker/?atid=128&group_id=9&func=browse
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
