This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
7f4b01ccf076998cac98c52aa6701f35e1c2500f
- Button option "Single" in render-layer panel will enable to only render the currently indicated render-layer. It will also skip compositing. - Brought back the 'Local View' render. This will only render the visible objects, but with lights from the original view-layers. To make the option useful, it also temporal enables 'Single', which has the a disadvantage that you need to set the correct render-layer. It is a bit a tricky option though... since its quite invisble and confusing for people who don't know the feature. This might become either a button in 3d header, or use a popup requester to confirm, or... will need to think over! At least; both options display in render window a text to denote the option.
Welcome to the fun world of open source. For instructions on building and installing Blender, please see the file named INSTALL. ---------------------.Blanguages and the .blender directory--------------------- The .blender directory holds various data files for Blender. In the 2.28a release those are the .Blanguages file containing a list of translations, the translations themselves and a default ttf font. Blender checks for the presence of this directory in several locations: - the current directory - your home directory - On OSX, the blender bundle is also checked - On Windows, the installation dir is checked. If you get a 'File ".Blanguages" not found' warning, try to copy the .blender dir to one of these locations (your home directory being recommended). -------------------------------------Links-------------------------------------- Getting Involved: http://www.blender.org/docs/get_involved.html Community: http://www.blender3d.org/Community/ Main blender development site: http://www.blender.org/ The Blender project homepage: http://projects.blender.org/projects/bf-blender/ Documentation: http://www.blender.org/modules.php?op=modload&name=documentation&file=index Bug tracker: http://projects.blender.org/tracker/?atid=125&group_id=9&func=browse Feature request tracker: http://projects.blender.org/tracker/?atid=128&group_id=9&func=browse
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
