This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Hans Goudey 7f958217ad Curves: Use shared caches for evaluated data
Use the `SharedCache` concept introduced in D16204 to share lazily
calculated evaluated data between original and multiple evaluated
curves data-blocks. Combined with D14139, this should basically remove
most costs associated with copying large curves data-blocks (though
they add slightly higher constant overhead). The caches should
interact well with undo steps, limiting recalculations on undo/redo.
Options for avoiding the new overhead associated with the shared
caches are described in T104327 and can be addressed separately.
Simple situations affected by this change are using any of the following data
on an evaluated curves data-block without first invalidating it:
- Evaluated offsets (size of evaluated curves)
- Evaluated positions
- Evaluated tangents
- Evaluated normals
- Evaluated lengths (spline parameter node)
- Internal Bezier and NURBS caches
In a test with 4m points and 170k curves, using curve normals in a
procedural setup that didn't change positions procedurally gave 5x
faster playback speeds. Avoiding recalculating the offsets on every
update saved about 3 ms for every sculpt update for brushes that don't
change topology.
Differential Revision: https://developer.blender.org/D17134
2023-02-03 12:19:40 -05:00
2023-01-30 23:48:41 +01:00
2021-10-23 10:49:51 +05:30
2023-02-02 13:16:39 +01:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
2023-01-31 15:49:04 +11:00
2022-06-28 15:56:16 +02:00
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
Blender screenshot
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
