This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Ton Roosendaal 8355aa0cf0 Strand render/zbuffering optimize recode
I've been going over the zbuf.c code, which is indeed very ancient,
with a load of old optimizing and redundant code in use.
Added more 'modern' Span support, which fills per face two arrays
with the scanline information in it. That way you can zbuffer a quad in one
run as well. It was also exactly that code that's copied all over in zbuf.c
For now, to prevent issues for the release, the 'render a quad in 1 run' is
only in use for the strand render. Tests reveil a speedup of about 33%.
Will work on this recode later... which would also result in making zbuf.c
threadsafe.
And: bugfix #3398
When using the new 'render emitter' for particles, the orco array for
particles was accidentally used by mesh too.
2005-11-14 14:27:44 +00:00
2005-01-05 10:27:48 +00:00
2005-06-06 12:18:44 +00:00
2005-11-11 20:15:16 +00:00
2005-11-02 15:59:14 +00:00
2005-11-03 20:07:55 +00:00
2004-08-24 02:51:07 +00:00
Welcome to the fun world of open source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/docs/get_involved.html
Community:
http://www.blender3d.org/Community/
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender/
Documentation:
http://www.blender.org/modules.php?op=modload&name=documentation&file=index
Bug tracker:
http://projects.blender.org/tracker/?atid=125&group_id=9&func=browse
Feature request tracker:
http://projects.blender.org/tracker/?atid=128&group_id=9&func=browse
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
