This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Martijn Versteegh 83fa6a1b2a Fix T95249: bake margin adjacent faces fails in some directions
The new adjacent faces method border lookup fails in some directions around
45 degrees
* Use 8 Dijkstra directions (also diagonally) to determine which polygon is the
  closest to each pixel. Using only Manhattan distance lead to large parts of
  the texture which were matched with the wrong polygon.
* Use neighbroing polygons for edge search. The Adjacent Faces algorithm needs
  to determine the closest edge, in UV space, each pixel. To speed this up
  first as map is built which finds the closest polygon for each pixel along
  horizontal, vertical and diagonal steps. Because this can sometimes be one
  edge off we first look in the polygon from the map, if that fails also
  check the edges of its neighbouring UV polygons.
Differential Revision: https://developer.blender.org/D13935
2022-01-31 18:18:04 +01:00
2021-10-23 10:49:51 +05:30
2022-01-23 22:34:56 -06:00
2022-01-28 11:32:12 +01:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
2022-01-25 09:19:03 -07:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/83fa6a1b2afb73a2d84cc5c45f0a34ea900ea0b2/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
