This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Sergey Sharybin 8ac1d8a4ea Fix #33650: Compositor locks up when input is an unrendered render layer.
Issue was caused by resolution detecting which assumed zero resolution is
undefined one and should be re-evaluated. It doesn't work in cases when
there's a missing input, causing lots of unneeded resolution re-calculation.
It wasn't so much issue in average sized node trees, but it was a real
problem in generated tree from the report.
Currently used pretty simple solution which added a boolean flag to the
node operation which signal whether resolution was ever set or not.
There're probably smarter solutions here but can not think about them.
2012-12-24 13:33:47 +00:00
2010-10-13 14:44:22 +00:00
2012-12-18 19:35:54 +00:00
S
Archive of Blender with old branches
823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
