This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Jeroen Bakker 8fb2ff458b GPUShaderCreateInfo for interface abstraction
This is a first part of the Shader Create Info system could be.
A shader create info provides a way to define shader structure, resources
and interfaces. This makes for a quick way to provide backend agnostic
binding informations while also making shader variations easy to declare.
- Clear source input (only one file). Cleans up the GPU api since we can create a
  shader from one descriptor
- Resources and interfaces are generated by the backend (much simpler than parsing).
- Bindings are explicit from position in the array.
- GPUShaderInterface becomes a trivial translation of enums and string copy.
- No external dependency to third party lib.
- Cleaner code, less fragmentation of resources in several libs.
- Easy to modify / extend at runtime.
- no parser involve, very easy to code.
- Does not hold any data, can be static and kept on disc.
- Could hold precompiled bytecode for static shaders.
This also includes a new global dependency system.
GLSL shaders can include other sources by using #pragma BLENDER_REQUIRE(...).
This patch already migrated several builtin shaders. Other shaders should be migrated
one at a time, and could be done inside master.
There is a new compile directive `WITH_GPU_SHADER_BUILDER` this is an optional
directive for linting shaders to increase turn around time.
What is remaining:
- pyGPU API {T94975}
- Migration of other shaders. This could be a community effort.
Reviewed By: jbakker
Maniphest Tasks: T94975
Differential Revision: https://developer.blender.org/D13360
2022-01-17 14:32:28 +01:00
2021-10-23 10:49:51 +05:30
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/8fb2ff458ba579dba08bfdf57d043ad158b5db07/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
