This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Sergey Sharybin 991eac85ff Initial implementation of mdisps layer interpolation
Sculpt data shouldn't be lost when making topology changes without
quads<->tris face converison.
General idea:
- Go through all grid points of each corner and convert per-corner
  coordiante to per-face cooredinate
- Apply weights and convert new point to per-corner coordinate
- Use bilinear interpolation to get needed displacement vector
Some additional work was necessery:
- Two neighbour corners could have different displacements along common
  boundary. multires_mdisp_smooth_bounds() makes displacement "symmetrical"
- Point could change it's corner, so displacement vector should be flipped
  in some way. In some cases it's not only flipping, because corner could
  be mapped with some rotation. It's not solved for triangular faces yet,
  so only z-axis displacement would be interpolated for tris.
More limitations:
- Interpolation will give incorrect result after quad<->triangle
  face conversion.
- When face normal was fillped displacement would change it's direction too.
2010-12-13 21:22:30 +00:00
2010-07-26 11:47:33 +00:00
2010-12-08 11:42:11 +00:00
2010-10-13 14:44:22 +00:00
Archive of Blender with old branches
823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
