This repository has been archived on 2023-10-09 . You can view files and clone it. You cannot open issues or pull requests or push a commit.
c13754e6475e438ebd2fbafa2e51aa58504dc5f9
Fix for T84928 . Considering the changes , issue is resolved ( Ignoring readability issues) . **Changes **: - `Change in value assignment of fu/v/w :` Observing previous code , I noticed ,value assigned to them is equivalent to -0.5 ( i.e. co-ordinate of left most vertex of lattice size =1 where centre of lattice is origin ) . - `Change in value assignment of du/v/w :` Margin ( distance ) between each division of surface along any axis is equivalent to **( (length of surface along axis ) / (no of division line - 1) )** . that's why is changed it to (default_size/unew -1) . - ` New variable declared "default_size" :` As far as I gone through the code , I noticed values 1 < du ,fu < 1 , which indicates these values were calculated with respect to default lattice of size 1 . - `removed pntsu/v/w != 1 check :` Following changes inside the if block worked properly for pntsu/v/w = 1 . Reviewed By: lichtwerk, campbellbarton Differential Revision: https://developer.blender.org/D10353
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
Project Pages
Development
License
Blender as a whole is licensed under the GNU Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
