This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Ken Hughes cb0aa467cd Tools
New boolean merge algorithm.  The current code often does a poor job of merging tris and quads after the operation, resulting in many unnecessary faces.  This commit add a new algorithm which takes advantage of topology information saved in the interal BOP structures.
The file intern/boolop/intern/BOP_Misc.h has two #defines which control which algorithm(s) are compiled.  They are set now to compile both, with the new algorithm as the default.  The original algorithm can be enabled by setting the "rt" debugging button on the Scene panel (F10) to 100.
One note: the current boolean code still occasionally creates a non-manifold mesh from an operation on two manifold meshes.  The original merge algorithm would sometimes "close" these meshes and sometimes not.  The new algorithms behaves the same way, but sometimes closes a mesh the original would not and sometimes leaves open a mesh the original would close.  My fairly extensive tests did not indicate any significant difference in the percentage of final non-manifold meshes.
2008-07-31 18:37:03 +00:00
2008-06-02 21:35:57 +00:00
2008-06-22 15:48:12 +00:00
2007-10-02 12:36:53 +00:00
2008-07-28 10:13:56 +00:00
Welcome to the fun world of open source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/community/get-involved
Community:
http://www.blender.org/Community
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender
Documentation:
http://www.blender.org/education-help
Bug tracker:
http://www.blender.org/development/report-a-bug
Feature request tracker:
http://wiki.blender.org/index.php/Requests
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
