This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Jacques Lucke d09b1d2759 Fix T94464: video texture is not refreshing
In the past that worked because the `GPUMaterial` referenced the
`ImageUser` from the image node. However, that design was incompatible
with the recent node tree update refactor (rB7e712b2d6a0d257d272e).
Also, in general it is a bad idea to have references between data that is
owned by two different data blocks.
This incompatibility was resolved by copying the image user from the node
to the `GPUMaterial` (rB28df0107d4a8). Unfortunately, eevee depended
on this reference, because the image user on the node was update when the
frame changed. Because the image user was copied, the image user in the
`GPUMaterial` did not receive the frame update anymore.
This frame update is added back by this commit. The main change is that
the image user iterator now also iterates over image users in `GPUMaterial`s
on material and world data blocks. An issue is that these materials don't
exist on the original data blocks and that caused the check in
`build_animation_images` in the depsgraph to give the wrong answer.
Therefore the check is extended.
Right now the check is not optimal, because it results in more depsgraph
nodes than are necessary. This can be improved when it becomes cheaper
to check if a node tree contains any references to a video texture.
The node tree update refactor mentioned before makes it much easier
to construct this kind of run-time data from the bottom up, instead of
scanning the entire node tree recursively every time some information
is needed.
2021-12-31 14:24:11 +01:00
2021-10-23 10:49:51 +05:30
2021-12-14 20:56:11 +11:00
2021-12-02 18:43:42 +01:00
2021-12-16 20:54:04 +01:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/d09b1d2759861aa012ab2e7e4ce2ffa2b56bd9d3/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
