This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Tamito Kajiyama db71b5ef88 Partial fix for Bug #35695: Freestyle produces extra line across an object with pointed areas.
The reported problem is a visual artefact (extra lines) generated by
ChainingIterators.pySketchyChainingIterator used for sketchy chaining with the Same Object
option disabled in the Parameter Editor mode.  The issue is caused by an inconsistency in
the internal data structure (i.e., view map).  For now this fatal error condition is addressed
to avoid visually incorrect results.  Another fix will follow to address the cause of the
internal inconsistency.
2013-07-04 20:24:22 +00:00
2013-06-01 10:30:46 +00:00
2010-10-13 14:44:22 +00:00
S
Archive of Blender with old branches
823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
