This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Hans Goudey dedc679eca Geometry Nodes: Split transfer attribute node
This patch replaces the existing transfer attribute node with three
nodes, "Sample Nearest Surface", "Sample Index", and "Sample Nearest".
This follows the design in T100010, allowing for new nodes like UV
sampling in the future. There is versioning so the new nodes replace
the old ones and are relinked as necessary.
The "Sample Nearest Surface" node is meant for the more complex
sampling algorithms that only work on meshes and interpolate
values inside of faces.
The new "Sample Index" just retrieves attributes from a geometry at
specific indices. It doesn't have implicit behavior like the old
transfer mode, which should make it more predictable. In order to not
change the behavior from existing files, the node has a has a "Clamp",
which is off by default for consistency with the "Field at Index" node.
The "Sample Nearest" node returns the index of the nearest element
on a geometry. It can be combined with the "Sample Index" node for
the same functionality as the old transfer node. This node can support
curves in the future.
Backwards compatibility is handled by versioning, but old versions can
not understand these nodes. The warning from 680fa8a523 should make
this explicit in 3.3 and earlier.
Differential Revision: https://developer.blender.org/D15909
2022-09-23 13:56:35 -05:00
2021-10-23 10:49:51 +05:30
2022-08-15 16:10:29 +02:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
2022-01-25 09:19:03 -07:00
2022-06-28 15:56:16 +02:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/dedc679ecabb43e79b0160a7c64bbd616adfa829/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
