This repository has been archived on 2023-10-09 . You can view files and clone it, but cannot push or open issues or pull requests.
df751516e1f64bbc78b02582c631c3cdd0bc032d
The DWA compression code in OpenEXR has hardcoded rules which decides which channels are lossy or lossless. There is no control over these rules via API. This change makes it so channel names of xyzw is used for cryptomatte passes in Cycles. This works around the hardcoded rules in the DWA code making it so lossless compression is used. It is important to use lower case y channel name as the upper case Y uses lossy compression. The change in the channel naming also makes it so the write code uses 32bit for the cryptomatte even when saving half-float EXR. Fixes T96933: Cryptomatte layers saved incorrectly with EXR DWA compression Fixes T88049: Cryptomatte EXR Output Bit Depth should always be 32bit Differential Revision: https://developer.blender.org/D15823
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
Languages
C
67.4%
C++
23.4%
Python
6.1%
CMake
1.5%
GLSL
1.1%
Other
0.4%
