This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Joshua Leung e1fdf7fc58 View2D/TimeCode Drawing:
This commit introduces a few cleanups and tweaks to the way that timecodes (i.e. the timing indications used instead of frame numbers) get displayed.
1. Custom Spacing of TimeCodes/Gridlines
Made the minimum number of pixels between gridlines/timecode indications a user-preference, instead of being a hardcoded constant. This allows to set the spacing tighter/looser than the defaults, and is also used for the other changes.
2. Default timecode display style, (now named 'minimal') uses '+' as the delimeter for the sub-second frames. This hopefully makes it a bit clearer what those values represent, as opposed to the '!', which can sometimes look too much like a colon.
3. Added various timecode display styles as user-preference. - These include always displaying full SMPTE, to showing milliseconds instead of frams for sub-second times, and also an option to just show the times as seconds only.
- When changing the timecode style, the spacing setting is automatically modified so that the timecodes are spaced far apart enough so that they won't clash (under most circumstances). This automatic modification is only done if the spacing is too tight for the style being set.
4. Unified the code for generating timecode strings between the View2D scrollbar drawing and the current frame indicator drawing.
2010-01-30 04:43:36 +00:00
2010-01-19 21:42:01 +00:00
2010-01-20 03:46:28 +00:00
2010-01-15 09:59:42 +00:00
Welcome to the fun world of open source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/community/get-involved
Community:
http://www.blender.org/Community
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender
Documentation:
http://www.blender.org/education-help
Bug tracker:
http://www.blender.org/development/report-a-bug
Feature request tracker:
http://wiki.blender.org/index.php/Requests
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
