This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Sergey Sharybin e46c49ff3d Fix T53788: Camera animation not working
Both object level and camera datablock properties animation did not work with
copy on write enabled.
The root of the issue is going to the fact, that all interface elements are
referencing original datablock. For example, View3D has pointer to camera it's
using, and all areas which does access v3d->camera should in fact query for
the evaluated version of that camera, within the current context.
Annoying part of this change is that we now need to pass depsgraph in lots
of places. Which is rather annoying.
Alternative would be to cache evaluated camera in viewport itself, but then
it makes it annoying to keep things in sync.
Not sure if there is nicer solution here.
Reviewers: dfelinto, campbellbarton, mont29
Subscribers: dragoneex
Differential Revision: https://developer.blender.org/D3007
2018-01-19 11:12:22 +01:00
2017-10-21 12:43:17 +11:00
2017-05-01 15:20:19 +02:00
2010-10-13 14:44:22 +00:00
2017-12-12 13:55:09 +11:00
S
Archive of Blender with old branches
823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
