This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Maarten Gribnau e5f7a4f58b OSX Project Builder project for makes_dna, blender and player targets.
After building intern with the Makefile, this project builds all three targets.
blender and player targets are dependent on makes_dna so that dna.c is generated
automatically (at the moment it is created evry build).
The applications are complete with icons and file type registering.
The only catch is that it might be necessary to symlink the darwin-6.1-powerpc
directory if your kernel is no on 6.1.
Maarten
2002-12-13 21:34:52 +00:00
2002-11-04 21:55:48 +00:00
2002-12-12 21:16:46 +00:00
2002-11-15 06:57:59 +00:00
Welcome to the fun world of open-source.
This file is to help you get started using the source and will hopefully
answer most questions.
Here are some links to external packages you may or maynot need:
openssl:  http://www.openssl.org
python:  http://www.python.org
mxtexttools:http://www.egenix.com/files/python/mxTextTools.html (python lib)
libjpeg:  http://www.ijg.org/
libpng:  http://www.libpng.org/pub/png/
zlib:   http://www.gzip.org/zlib/
ode:	http://q12.org/ode/ode.html
openal:  http://www.openal.org/home/		(for linux/windows)
	sdl: http://www.libsdl.org/index.php (for openal)
	smpeg: http://www.lokigames.com/development/smpeg.php3 (for openal)
fmod: http://www.fmod.org/
mozilla: http://www.mozilla.org/
nspr:  ftp://ftp.mozilla.org/pub/nspr/releases
	(side note: on debian linux you will need mozilla-dev and libnspr-dev)
If you do not have GL you will also need mesa:
http://www.mesa3d.org
We are in the process of moving things over to automake/autoconf
The old makefiles are still in place and will work.
If you want to get a working blender skip down to the next section
and use this readme as a guide.
If you want to play with the new autoconf environment take a look at
doc/autoconfig.txt
--Notes on compiling mxTextTools----------------------------------------------
To get the latest version to compile on my machine I had to
edit mxSetup.py and remove /usr/include from INCLPATH for it to build
properly.
(after doing this you need to edit blender/source/Makefile and
fix the pointer to it I'm still working on automating this)
--------------Basic Makefile TIPS---------------------------------------
Assuming you are using tcsh/csh do the following before compiling.
#Set this to wherever you have extracted the source.
setenv NANBLENDERHOME `pwd`
setenv MAKEFLAGS "-w -I$NANBLENDERHOME/source"
Or for bash/sh do this:
NANBLENDERHOME=`pwd`
export NANBLENDERHOME
MAKEFLAGS="-w -I$NANBLENDERHOME/source"
export MAKEFLAGS
Then edit source/nan_definitions.mk to fit you're environment.
(You'll want to change things like NAN_OPENSSL,NAN_JPEG, NAN_PNG etc..
to point to where you have it installed)
If you tried to just have a go at making stuff you might wind up with
an empty file /tmp/.nanguess
You need to remove the empty file and it will get created automatically
by $NANBLENDERHOME/source/tools/guess/guessconfig after you have
setup the NANBLENDERHOME variable.
After that cd $NANBLENDERHOME/intern
make
make install
cd $NANBLENDERHOME/source/ode
Look at the README_BLENDER and follow instructions
Then cd $NANBLENDERHOME/source
make
If you have any problems with the above post a message to the Forums on
www.blender.org
----------------------WINDOWS TIPS--------------------------------------
www.blender.org
----------------------Mac OSX TIPS--------------------------------------
Now before you go to the source directory, make sure you have installed the
external libraries that Blender depends upon. Here is a description of the
things you need.
FINK:
Use fink (http://fink.sourceforge.net/) to install the following libraries that
Blender depends on:
1. openssl (fink install openssl)
2. jpeg    (fink install jpeg)
3. png     (fink install png)
PYTHON:
Mac OSX 10.2 (Jaguar) now comes with Python (2.2.1) pre-installed. This is fine
for producing the "frozen" Python code found in the intern directory. However,
the installation does not contain the python library to link against (at least
I could not find it). You could use fink to install Python but that Python
installation depends on X being installed and that is a large installation.
If you prefer the easy way: download Python 2.2.2 from http://www.python.org.
Follow the instructions to in the documentation to install it on your box. If
you run OSX 10.2 it should install just fine. Basically a configure and a
"make" will do the job. The result is a Python library that should be copied to
the library tree together with the associated header files.
Create the following  directories:
$NANBLENDERHOME/lib/darwin-6.1-powerpc/python/include/python2.2
$NANBLENDERHOME/lib/darwin-6.1-powerpc/python/lib/python2.2/config
Now copy the include files and the libpython2.2.a library to those locations.
FMOD:
Download FMOD from http://www.fmod.org/ and unpack with StuffIt Expander. The
archive contains header files and a library. Copy those to these directories
(that you need to create first):
$NANBLENDERHOME/lib/darwin-6.1-powerpc/fmod/include
$NANBLENDERHOME/lib/darwin-6.1-powerpc/fmod/lib
RANLIB:
Although the make files run ranlib on the libraries built, the gcc linker
complains about ranlib not being run. Until there is a solution, you will need
to run ranlib by hand once in a while when the make breaks. Luckily, the error
message lists the full path of the file to run ranlib on... Anybody out there
with a real solution? I guess the problem arises from copying the files from
one location to the other...
Now wait, don't type make yet! You'll have to edit a config file of ODE first.
go to $NANBLENDERHOME/source/ode/config and edit the file "user-settings" so
that platform is equal to osx (PLATFORM=osx).
Success!
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
