This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Hans Goudey ec1b0c2014 Geometry Nodes: Initial merge by distance node
This implements a merge by distance operation for point clouds.
Besides the geometry input, there are two others-- a selection
input to limit the operation to certain points, and the merge
distance. While it would be a reasonable feature, the distance
does not support a field currently, since that would make
the algorithm significantly more complex.
All attributes are merged to the merged points, with the values
mixed together. This same generic method is used for all attributes,
including `position`. The `id` attribute uses the value from the
first merged index for each point.
For the implementation, most of the effort goes into creating a
merge map to speed up attribute mixing. Some parts are inherently
single-threaded, like finding the final indices accounting for the
merged points. By far most of the time is spend balancing the
KD tree.
Mesh support will be added in the next commit.
Differential Revision: https://developer.blender.org/D13649
2022-01-25 10:51:52 -06:00
2021-10-23 10:49:51 +05:30
2022-01-23 22:34:56 -06:00
2021-03-26 16:15:02 +01:00
2010-10-13 14:44:22 +00:00
2022-01-25 09:19:03 -07:00
Sphinx Warnings
: WARNING: Could not obtain image size. :scale: option is ignored.
Note the preview is not accurate and warnings may not indicate real issues.
Blender
Blender is the free and open source 3D creation suite. It supports the entirety of the 3D pipeline-modeling, rigging, animation, simulation, rendering, compositing, motion tracking and video editing.
https://projects.blender.org/archive/blender-archive/media/commit/ec1b0c2014a8b91c27bc5478ffa1ca74b63c64e9/https://code.blender.org/wp-content/uploads/2018/12/springrg.jpg
Project Pages
Development
License
Blender as a whole is licensed under the GNU General Public License, Version 3. Individual files may have a different, but compatible license.
See blender.org/about/license for details.
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
