This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Lukas Tönne fd553c5b7b Fix T37334: Better "internal links" function for muting and node disconnect.
Implements a more flexible internal connect function for standard nodes
(compositor, shader, texture). Allow feasible datatype connections by
priority.
The priorities for common datatypes in compositor, shader and texture
nodes are encoded in a simple function. Certain impossible connections
(e.g. color -> cycles shader) are excluded by giving them -1 priority.
Priority overrides link status: If a higher priority input can be found,
this will be used regardless of link status. Link status only comes into
play for inputs with same priority.
Reviewers: brecht
CC: sebastian_k
Differential Revision: https://developer.blender.org/D356
2014-03-02 16:04:25 +01:00
2014-02-28 19:09:22 +06:00
2013-11-21 16:51:29 +01:00
2013-12-24 22:57:27 +06:00
2010-10-13 14:44:22 +00:00
S
Archive of Blender with old branches
823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
